Confirming clearance
I recently went up to a MT in the 285 75 16. I want to make sure that I am clearing the tire everywhere before I drive all the way to Barnwell to do some offroading. I have trimmed the flares, pounded the pinch weld and done everything I can think of to make sure that I clear these tires. Now I am not sure how to test it before I make the 2 hour trip to Barnwell Mountain just to find out I have alot of work left to do.
I have a high curb (about 16") next to the house. I put each of the front tires up on that curb and turned the wheel to full lock in each direction. I cleared the pinch weld and the flare in the front. I also put my floor jack under each of the front lower control arms and jacked the truck up and checked the clearances this way.
There really isn't anywhere that I can legally get offroad around the house. I just want to make sure I don't make a 2 hour drive just to have to spend all day under the truck with the BFH.
Well if you put each front tire up on the curb one at a time you should be alright...If you really that worried about a little rub do the same with the rear. One at a time.
If your still not happy take a cordless sawsall with you and cut out what you need while your out there.
Thanks, probably will at least take the BFH with me. I don't have a cordless sawzall but I do have a corded one and an 1800 watt inverter. Hopefully I don't still have that much trimming left.
kawazx636
10-06-2021 03:03 PM
scott90
10-04-2015 09:21 AM
Odin
09-26-2015 06:56 PM
