Check engine light on How to pull the code?
Old Feb 19, 2007 | 12:03 PM
Gideon's Test's Avatar
My check engine light came on today. Is there a way to pull the engine code? I know that for domestic vehicles you short two of the pins on the diagnostic port and the check engine light will flash out the trouble codes. Is there a similar procedure for the 4Runner?
Thanks.
EDIT: BTW, I googled this http://www.off-road.com/toyota/tech/codes/
Does this look correct?
Old Feb 19, 2007 | 12:26 PM
MTL_4runner's Avatar
Thanks.
Nope, that won't work on vehicles newer than 1995.
You need to get, rent, borrow, etc an OBD II code reader. There is no way to access codes like you used to anymore. The local Autozone will often read them for free if you're lucky. Search OBD on here and you'll find tons of info on how to do it and what readers to buy.
https://www.yotatech.com/search.php?searchid=2721843
Old Jul 5, 2007 | 11:30 AM
slinkyeleven's Avatar
Diagostic Tools
Walmart carries a 3030 from Innova for $60, it works well and will help solve your problem
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
