Change your spark plugs every 30k
Old 07-11-2011, 11:17 AM
Texas_Ace's Avatar
I have not had any problems with the 6 but i have also not pulled them to see what they look like yet either.
I am taking my experience from MR2's any applying it to the 4runner. In the MR2 if you use 2 steps colder the plugs get fouled VERY fast. Usually you get reduced performance within a few hundred miles.
I am running water/meth injection though so not sure how a 1 step colder would work without that. I plan to stick with 1 step colder plugs in my truck though unless these plugs look like they are too hot when i pull them out.
Old 07-11-2011, 12:10 PM
mt_goat's Avatar
I doubt you'll have fouling with water/meth injection. I don't with IK22s and they are 2 steps cooler, just lots of wear.
Old 07-11-2011, 04:31 PM
mt_goat's Avatar
I ordered up 6 NGK BKR6EK PB-11 to try. They are double platinum plugs (2 ground straps which are platinum tipped also), they are expensive at $10 each and a step hotter than I'd prefer but there just isn't a good choice for a 2 step cooler plug for the 5VZFE IMHO. Very frustrating but hopefully these will work out.
Old 07-11-2011, 04:53 PM
Texas_Ace's Avatar
You run water injection right? you should be ok, if you were on plain gas and pullyed think i would stick to 2 steps cooler till it is proven ok on plain pump gas.
Old 07-11-2011, 04:57 PM
  #25
mt_goat's Avatar
Yes, 50/50 water/meth Aquamist 2D system.
Old 07-11-2011, 04:58 PM
  #26
Texas_Ace's Avatar
Old system but as long as it is working i doubt you will have any problems.
Old 07-11-2011, 05:11 PM
  #27
mt_goat's Avatar
Yeah getting old, like me lol...funny you should say as long as its working, I've had 2 leaks this year. I guess I need to replace all of the lines.
Old 07-11-2011, 05:31 PM
  #28
J2F42C's Avatar
Dale,
I thought you were looking into getting some Denso plugs from overseas? Did that never materialize?
BTW, where have you been hiding out? Somewhere that has AC hopefully. A friend in Tulsa says hell has nothing on the hot heat in OK at the moment.
Old 07-11-2011, 05:46 PM
  #29
mt_goat's Avatar
Originally Posted by J2F42C
Dale,
Yeah I can't bring myself to buy plugs in some foreign currency and pay God knows what in shipping.
Yeah what a heat wave, but I just got back from Breckenridge CO and 2 trails had so much snow I couldn't get through to the top. Nice a cool up there (about 10,000 ft).
Old 07-20-2011, 11:32 AM
  #30
mt_goat's Avatar
New plugs are ready to go in, I like that the tip (top) doesn't unscrew. Some have reported the tips unscrewing during use and causing problems (other types of plugs)
Old 07-20-2011, 11:38 AM
  #31
Texas_Ace's Avatar
Those may have been the plugs i used last, i know i ran some plugs like that at some point. Worked fine for me but still didn't last all that long but i am real picky about my plugs.
Old 07-20-2011, 02:10 PM
  #32
josh.bunch's Avatar
Just changed mine last weekend for the first time in over 130K and they didn't look that bad.
Or that good.
Old 07-20-2011, 02:18 PM
  #33
Texas_Ace's Avatar
Actually they do look real bad, look at those gaps!
Old 07-20-2011, 02:48 PM
  #34
TheDurk's Avatar
Well, they look pretty good for 130K! Seriously, those were toast a long time ago.
Old 07-20-2011, 02:51 PM
  #35
Texas_Ace's Avatar
Yeah, for 130k i guess they could be worse although not sure how much worse.
Bet that truck drives like new after that change!
Old 07-20-2011, 03:34 PM
  #36
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
do i ever need to do this asap... thanks for the prodding folks!
Old 07-20-2011, 04:35 PM
  #37
SierraMtns's Avatar
So which ones should I use with a stock 02 3.4? NKG or Denso? I have a Napa and Toyota dealership right next to each other.
Old 07-20-2011, 04:37 PM
  #38
Texas_Ace's Avatar
Doesn't really matter on a stock truck long as you change them out.
Old 07-20-2011, 04:47 PM
  #39
smokey0066's Avatar
I usually buy ngks. Its so easy to change them out there really is no excuse. Unlike the rear bank of my Camry... grrr
Old 07-20-2011, 05:21 PM
  #40
mt_goat's Avatar
OMG, those are toast.
Quick Reply: Change your spark plugs every 30k
