Catalytic converter help
Old Nov 20, 2004 | 09:10 PM
obxfishn's Avatar
My 02 Taco just ran out of its factory warranty period and my check engine light came on. I plugged an OBDII reader and it gave a code of P0420 Catalyst System Efficiency Below Threshold (Bank 1). WTF the warranty is out and now I am stumped why the CAT would start screwing up now. I erased the code and now the check engine light is back on. Does anyone have a CAT they want to sell or how can I unplug the sensor for that error code? Or does anyone know what I should do now?
Old Nov 20, 2004 | 09:14 PM
NorCalVP's Avatar
You have an emissions system warranty until 80K miles.....
Old Nov 21, 2004 | 06:24 AM
rimpainter.com's Avatar
Yep, and if for some reason that doesn't pan out for you, no worries. An aftermarket high flow cat will run you about $100 +install.
Let us know what the dealer says.
Old Nov 21, 2004 | 06:41 AM
CynicX's Avatar
it should pan out for you....the emmision warrenty is 8yr/80k miles...whichever comes first....of course I guess if you have major engine mods they could try something to make you pay for it....
Old Nov 21, 2004 | 06:51 AM
obxfishn's Avatar
Where can I get a high flow cat from and will it affect the computers sensor readings?
Old Nov 21, 2004 | 06:56 AM
Well, if your cat is truly bad, then get a new Toyota one under warranty. If Toyota will not cover it for whatever reason, and that is the problem, then get a Carsound cat off ebay.
You really should push this with the dealer though...unless you have a mod that would directly affect the malfunction. But, judging by your sig, you don't.
A Carsound cat will operate with your computer.
Old Nov 24, 2004 | 06:02 AM
lash92ssei's Avatar
Call Toney's Muffler Shop in Richmond at 804-231-6063. I had them do my 99 4runner. Former President of Local F-173
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
