Carbon cleaning
I don't know what this process is, but I bet if your engine has a lot of buildup, and whatever they do removes the carbon, it would probably improve your mileage and decrease friction and wear....
A bottle of carbon cleaner costs about 8 bucks, and you'll need some extra hose to run from the bottle to the vacuum line, which costs about another 2 bucks... so figure 10 bucks for a cleaner engine. Not a bad deal at all if you ask me. Jroc knows how to do it, so I'm getting mine done soon. I'll take some pics and let you guys know which vacuum line to hook it up to.
Either Gadger or Corey (or both) did some kind of engine clean that seemed to work well. Check out www.gadgetonline.com, it might be on his site.
Guest
Posts: n/a
can't warn you more about this! This is EXACTLY what I did to my engine and it snapped a rod, costing a new engine. There isn't really much you can do other than take it all apart and clean it that way.
The proper technique is to clamp the vacuum line with a pair of vice grips, or something similar, then start the engine. Slowly release the clamp, but keep it partially closed so that it takes 3 to 5 minutes to empty the container.
BTW, I've used plain water for 40 years with good success to de-carbonize a hot engine. It turns into steam, which fractures the carbon in the combustion chamber, and the exhaust stroke blows it out of the engine.
Google this topic for much more information that you ever wanted to know. Google is your friend.
Best regards,
Bill
Originally posted by oly884
I can't warn you more about this! This is EXACTLY what I did to my engine and it snapped a rod, costing a new engine. There isn't really much you can do other than take it all apart and clean it that way.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
