Can't remove CrankShaft Pulley bolt
Old 03-07-2008, 06:28 PM
denet's Avatar
I am replacing my 96 4runner 4WD V6 3.4l timing belt. And I can't remove crankshaft Pulley bolt. I used air gun(500lb torque) and doesn't move a bit.
Anyone has any idea to remove it without buying a special tool for it?
Thanks
Old 03-07-2008, 06:31 PM
fillsrunner4's Avatar
drop the oil pan and a few parts inside it so you can get a piece of wood to hold the crank while you break loose the bolt. That or SST
Old 03-07-2008, 06:38 PM
Another way people do it is crank the motor but be sure you unplug the ignitor before hand and place a breaker bar to the frame and it can break the bolt loose. I dont much like the idea but it works for some people.
See this also
https://www.yotatech.com/forums/f116...y-bolt-130240/
Old 03-07-2008, 06:43 PM
camo31_10.50's Avatar
yeah..crankin the motor with a breaker bar on the frame works FINE...did it on my '80 worked like a charm...only takes one click of the starter..lol..try that..it'll work..
Old 03-07-2008, 07:58 PM
prospectator's Avatar
X2 on using the starter. I used a C-clamp to hold the breaker bar to the frame. Just bump the starter a couple times and it comes right off. I know it sounds scary but it works great. It would be much easier than removing the oil pan and wedging wood between the block and crankshaft.
Old 02-23-2013, 04:13 PM
ChrisFromEverett's Avatar
I am not a fan of shade tree wrenching but I fought that dang crank bolt for 2 hours!! Heating, tapping, then big daddy impacting. Around and around I whent for 2 hours. On ONE BOLT! Then I found this thread. Whent out and gave it a try. Bang the bolt was loose in a second. I could have been done with my timing belt job had I done this from the start. Also do unplug the coils to be safe.
Cheers
Blamalam
03-12-2022 07:34 AM
TJWilly
07-31-2015 02:05 PM
yoterr
07-24-2015 04:29 AM
dinks07
07-15-2015 05:34 PM
Snort
07-09-2015 03:58 PM
Quick Reply: Can't remove CrankShaft Pulley bolt
