Camshaft/rocker arm question...
Old 10-28-2003, 12:17 AM
HurleyBoy's Avatar
im going to be putting an aftermarket camshaft in my truck and along with 2 new rocker arms...now heres the question, since im putting a aftermarket camshaft in there do i time this to the stock setting or to a new one or does it matter?
Old 10-28-2003, 04:21 AM
HurleyBoy's Avatar
Old 10-28-2003, 09:21 AM
Duffdog's Avatar
you forgot to say some stuff--
what engine???? what year, what camshaft. and by the way, if its a 22re, mark the distriutor before you remove it so that you dont skip a tooth when you put it back in. oh, and the timing remains stock for best gas mileage--advance it slightly for a little more power.
t
Old 10-28-2003, 09:54 AM
rimpainter.com's Avatar
Yeah more info please.
If you are asking whether or not the stock valve clearance is retained with an aftermarket cam, then the answer is no. The supplier of the cam or regrind should supply the new tappet clearances with a cold engine at TDC.
Old 10-28-2003, 10:07 AM
MTL_4runner's Avatar
I think you are talking about distributor advance / retard, correct?
I would set it to stock unless you want to run premium gas.
For a little more power, advance it a degree or two as suggested.
ladybugRC
458
08-21-2020 10:41 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
tylermx71
09-29-2015 08:49 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Camshaft/rocker arm question...
