Camber Adjustment after System 7
Old 01-29-2007, 02:36 PM
aquasport17's Avatar
So I was at the shop today getting my new 265/75 tires put on after my lift, and was discussing the alignment with the tech. He took a look and claims I'm going to need some sort of camber kit to get the camber dialed in after the Sonor system 7 went in. I think he's nuts, as I didn't read bout anyone doing that here, and Steve at Sonoran would have said something about it. Who's nuts me or him?
Jeff
Old 01-29-2007, 02:49 PM
Bighead's Avatar
No you won't need a "camber kit" (whatever that is). Go to another shop for your alignment.
Old 01-29-2007, 02:50 PM
Tanto's Avatar
x2
Tell your friends......NOT to go there
Old 01-29-2007, 02:57 PM
paddlenbike's Avatar
My experience:
https://www.yotatech.com/forums/f2/caster-adjustment-after-tundra-lift-101845/
Old 01-29-2007, 02:59 PM
Yeah that's pretty much what I figured! Okay.
Old 01-29-2007, 03:23 PM
I see online how I can make the camber measurement and maybe at least improve it somewhat before I get it to the shop- it's way out - what are the tricks to adjusting the cam bolts?
Old 01-29-2007, 03:26 PM
AxleIke's Avatar
a very long cheater bar.
Old 01-29-2007, 04:18 PM
toyotaoffroad91's Avatar
i brought my truck the the only 4x4 shop on long island within 150 miles of me...i spent 90 dollars on the alignment but the guy had problems at first but he did get it dialed in the the truck is as smooth as stock with 285's
Old 01-29-2007, 04:24 PM
Yeah - wish there was a good 4x4 shop near Cape Cod.
Old 02-01-2007, 05:44 PM
It lined up fine! I have a noise in the front end on Drivers side over rough surface - I think the spring is hitting the frame - gonna investigate when it warms up. Spring may not be on the shock straight, or I bent something putting it in. Sure looks sharp with the new Dueler Revos and the lift, though. The Wet Okole covers arrived today. Nice.
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Sarcazmo
08-15-2015 08:22 PM
Ernie217
08-14-2015 05:25 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Camber Adjustment after System 7
