Brake Pad FSM?
Brake Pad FSM?
I need pretty quick help on front brake pads on an 04 Tacoma. From what I've seen they are pretty easy. Don't even have to remove the calipers, unless you are turning the rotor.
From what I have seen, pull out retaining clips, then retaining pins, pads slide out of the top of the rotor, and then compress the pistons, and then slide everything back in in the opposite order, right?
If anyone has the FSM or any other helpful suggestions on this, I would be GREATLY appreciative. I am leaving for a long road trip, need to get these changed, tonite, if possible. Thanks guys!!!
Yep, you can do them without removing the calipers if you are going to do anything with the rotors.
http://www.deserted1.com/FSM/Repair_...4wdpr/repl.pdf
Jamie's typing too fast...
Originally Posted by MTL_4runner
Yep, you can do them without removing the calipers if you are NOT going to do anything with the rotors.
trailgoat
08-13-2015 05:54 PM
