Brake Issues
Old 12-20-2014, 01:35 PM
Sebastian F7's Avatar
Brake Issues
Ok so I got a 95 T100 with a 3.4 246k miles.
Did rear brakes last year and just now did fronts.
Pedal has always been mushy and goes down forever.
Put reman calipers on several new lines and a new-used master cylinder.
I have absolutely no leaks anywhere and have flushed over 2 liters of fluid thru this thing. 90% of the time I get awesome brakes and it will about pitch you thru the windshield. Then just randomly out of nowhere I won't get jack like nothing at all. I haven't been able to bleed the lspv because its all rusted to crap... However it seems to me like if that was the issue I wouldn't just randomly lose all brakes. Before I did fronts I had pedal and no brake warning light. Now I don't have much for pedal and the warning light stays on all the time.
I freaking lost... Usually non abs are simple press lever get brakes. If not you have a leak.
I've done several hours of googling with no success. I'm about ready to the thing.
Old 12-21-2014, 12:25 AM
wyoming9's Avatar
Red face
Have you replaced all the rubber hoses ??
Do you need to add more then the normal amount of brake fluid ??
To allow for pad wear .
You do use the Ebrake to keep the rear brakes adjusted.
Rear brake shoes hanging up some how then freeing themselves . Like the Emergency Brake hanging up at times.
Someplace you either have a caliper or some other blockage( Master Cylinder??) giving the feeling of a firm pedal every once in a while it works like it should hence the pedal goes to the floor.
Here in the Great Brine Belt I have never tried to bleed the LSPV after the first time. On all the Toyota`s I have done brakes on.
Some things to think about.
Old 12-21-2014, 01:00 PM
Had a leak so small I couldn't see it in a rear line. All fixed.
Spoke too soon. Made it about 5 miles and back to no brakes. More line swaps I guess.
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
CanRunner
07-20-2015 01:29 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake Issues
