Boost + ECT
Boost + ECT
From where we live, when we go to 'town", we have to get on I95 and go over 3 overpasses. I had noticed that going up the OP the boost/vacuum gauge would go from vacuum to around 2 lbs boost until about 2/3 way up and then drop back into vacuum and continue on up and over. The trans does not downshift.
A few days ago I had ECT on, which I don't usually do. Everything was as above , except the gauge went up only into "0", no boost at all. Hmmm
Today I tried it again and the gauge either stayed on the vacuum side or into the "0" region. Again no boost to go up the incline.
I am aware that the ECT changes the shift points in the trans, but this would seem to indicate that a different fuel map is used also, since the trans does not shift in either situation.
Has anyone else noticed this?
Longbed 90
03-11-2019 12:38 PM
Longbed 90
10-19-2015 11:05 AM
Boomer8404
09-20-2015 06:15 PM
