Bilstein struts.........Help me!!!!!
Old 03-30-2007, 01:13 AM
VZJ95L's Avatar
Hello everyone!!!! this is my first post for yotatech forum. it has been a very informative forum and i'm loving it!!! anyway, for those suspension expert here i hope you could help me.
I owned a 1998 Toyota Landcruiser Prado or 95 series. I've learned that it has the same suspension configuration with the 1997-2002 4runner in the US. I am currently using Bilstein shocks and struts with OEM toyota spring. in 2 months time i will be installing an arb deluxe bar it will surely drop the front so what is the best option to do without changing the Bilstein? do i have to install a spacer or change the spring? (what spring should i use) i dont do off roading just dont want the front end look sag.
Thanks for helping.....
Old 03-30-2007, 08:01 AM
BajaRunner's Avatar
You're springs will have a higher weight rating, due to the fact the LC is a much heavier vehicle.
Your best bet is to check out and call http://www.sleeoffroad.com/ as they are the landcruiser specialists.
The easiest thing would be to add a spacer up front. But, I had no idea that they had the same front end components as the 4runner.
Old 04-07-2007, 12:50 PM
icerunner's Avatar
Help Me Help Me Help Me!!!!!!!!!!!!!!!!!!!!!!!!!!!!111
"Bilstein struts.........Help me!!!!!"
HELP ME, HELP ME!!! MY LIFE IS OVER IF I DON"T GET THE RIGHT SUSPENSION!!!! OH NO!!!!
MY BALLS ARE KEPT IN MY GIRLFRIENDS PURSE......
I'M JUST A POOR NEWBEE WITHOUT A CLUE!
Seroiusly, i'm just messin!
actually I'm the newbee,
and I'm just messing around...... really
Last edited by icerunner; 04-07-2007 at 02:47 PM. Reason: Bilstein struts.........Help me!!!!!
Old 04-07-2007, 12:56 PM
Staff
DeathCougar's Avatar
Originally Posted by icerunner
HELP ME, HELP ME!!! MY LIFE IS OVER IF I DON"T GET THE RIGHT SUSPENSION!!!! OH NO!!!! MY BALLS ARE KEPT IN MY GIRLFRIENDS PURSE......
Seroiusly, i'm just kidding!
What the hell?!
Old 04-07-2007, 01:45 PM
MillerPKA's Avatar
yeah either ban or just know you're pretty wierd
ZGjethro
06-07-2017 11:04 PM
Scottcrb
03-03-2016 11:57 AM
JookUpVandetti
09-30-2015 08:58 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Bilstein struts.........Help me!!!!!
