Ball Joints ? Wheel bearings ??2000 Tacoma 4x4
Any thoughts on doing my front wheel bearings at the same time I do the ball joints ??
As things will be apart and to save me from doing another front end alignment
Getting close to 200,000 miles
Both inner and outer tie rods have all ready been done.
I don't know about doing the wheel bearings with the LBJs, but when i did my LBJs a few weeks ago it took no time at all.
PB Blaster soaking of the nuts and bolts a few times over the days before. Proper tools (which based on a lot of your comments I feel confident you have). I think I had 30 minutes in each side, 45 tops.
I would not worry with the bearings unless they are either giving you issues or you just have money to spend on OEM replacements. I would prefer 200k OEM's ro parts store replacements.
Like was said the LBJ are easy, and it would not be much easier to do the bearings now vs later, all of 4 bolts difference.
Are you doing the upper ball joints as well? If not then you will not be saving any time or energy besides 4 bolts. The upper ball joint is a pain BTW.
Avenged
07-09-2015 07:55 AM
