Backspacing?
Old 04-18-2003, 12:39 PM
JD's4RNR's Avatar
Backspacing?
I am gonna run 33x12.50 SSR's on 15 x8 black rockcrawlers. What backspacing should I run to keep the tires as much under the fender as possible without rubbing?
Old 04-18-2003, 07:51 PM
Red Chili's's Avatar
Does your rig have a suspension or body lift? It depends on the actual tire size. My rig has the OME suspension lift, 285's tires on 16x8 with 4 7/16" backspacing. It fits right inside the fender perfect, but I had to hammer on the inseam flatly on the firewall inside the front fender to clear out the tire rubbing. It usually does not get any rubbing under a normal driving condition except during a hard core at the off-road trail, you might see a slightly rubbing under a hard suspension punch. But, it was no big deal.
theduck21
09-10-2015 07:01 PM
Luvmeye22re
08-04-2015 03:53 PM
Cebby
11-19-2008 08:11 PM
ElwayLite
08-24-2004 04:23 AM
Quick Reply: Backspacing?
