Auto dimming mirror finally installed !!! :)
I love it. Easy install, and I like the look. I think it might have been worth it for the autodim alone. I must be lazy, since It's great not having to reach up and flip the mirror when someone's coming up on my a$$. I'm thinking of painting it to match, since I want to add the sunroof switch panel that you have,after I get my sunroof installed. I don't think the 4runner grey matches the Taco grey. If you don't mind, whats that little compartment to the right of the switches?
Thanks
Thanks
Thanks
Thanks
Could it hold a Garage Door opener, or something that size?
#26
Thanks for the help. If I can find it cheap at a yard, I might have to get one..
#27
yea, in fact it comes with a sticky pad, so you can stuck your garage opener in there and just click the compartment upward to open it... awesome feature which is lost on me as i am garage-less
#30
It is pretty straight forward to run the wire. You just have to hook on one power wire and one for ground and that it. I run the power wire through the fuse box, so the mirror will only turn on when the ignition is on.
#31
This is where I tap into the fuse box. The grey and red color wire is the power wire for the mirror. Let me know if you have any other question.
#32
So the 4Runner is the same as the Tacoma. I used that same open fuse slot for the a couple of taps, before I put in my aux fuse block.
06-01-2021 01:51 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
crashburnoveride
07-10-2015 06:39 AM
