Anyone run 285's on 17" tundra wheels
Old 03-01-2014, 08:23 AM
98 Black SR5's Avatar
Wanna run them when I do the 3" lift, just think I might need a 1" spacer. The BS is 4 3/4 or 5", can't really remember. I was thinking they might rub the UCA's without it. Any opinions???
Old 03-01-2014, 06:24 PM
KZN185W's Avatar
If the 17" Tundra wheels have a +15 offset, then it is the same as the stock N185L 4Runner wheels. Rubbing on the UCAs will be dependent on the tires you'll be running. Different tire brands have varying tire section widths even if they're of the same size. so best if you do a trial fit first.
Old 03-03-2014, 05:40 AM
hilgeg's Avatar
I run 285/70R17 with the Tundra wheels and I do use a spacer although it is just a 1/4inch (not the thread on type). Without the spacer you will rub on the UCA when flexing.
Old 03-03-2014, 07:12 AM
Ok. That's exactly what I wanted to know. Thanks
06-01-2021 01:51 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
skoti89
07-06-2015 07:45 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Anyone run 285's on 17" tundra wheels
