Anybody retrofit e-locker rear on 2002 4Runner with ATRAC?
#41
The owners of 4Runner, body 185 Your help is necessary!
Who has Rear Diff Lock!
I do not know how to mount the second large metal attachment to the body.
If You have any pictures, please put here.
The metal attachment is red marked on pictures.
#42
he is asking for help from those who have 3rd gen 4Runners (VZN185L and RZN185L) that are equipped with a rear differential lock. question 1. How to mount to the body the large metal bracket in the harness (e-locker harness?) question 2: If you can show pictures how the bracket is attached. not sure about this but the harness seems to be that of a 95 series prado not for a N185 (3rd gen 4Runner/Hilux Surf).
#43
From memory after swapping my e-locked axle from the 99 to the 02, that pic of the harness looks correct for the 185 (3rd gen 4runner). It bolted up near where the upper (stem end) of the left-hand side rear shock bolted in. Unfortunately, in my '02, that position was taken by a brakeline bracket so mine is not setup the same. Hopefully someone can get a pic.... HTH
-Ferg-
-Ferg-
#45
Thanks for your answer. Could you please take some pictures of your solution.
I have one more question:
Does REAR STABILIZER (BAR) hit against the e-locked axle in your car, when the rear axle goes down?
#49
can you notice a difference in driving when the stabilizer bar is removed??? i am getting ready to swap mine, and i am pretty sure all the brackets and mountings for the stabilizer bar are broken on the donor vehicle.......
#51
Sorry it took me so long... I was kinda hoping somebody could snap a pic of what theirs looks like in stock configuration. Here is what mine looks like. I've removed that bracket as I didn't have room for it. Stock configuration would have it mount just about--if not exactly--in the same spot as the brakeline bracket in my pics. HTH
-Ferg-
-Ferg-
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
icentropy
07-11-2015 07:21 AM
