Any tips before i install my lift this weekend? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-25-2008, 09:59 PM   #1 (permalink)
osker fenix's Avatar
Im installing my SAW coilovers and OME in back along with new shocks any tips or things to watch out for before i start?
I thought i read somewhere when installing the SAW's you need to manipulate the brake line a little or move it closer to the caliper, anyone have any insight on that?
thanks
__________________
-Brandon
01 4runner SR5 4x4 3.4 V6 110k miles- 2" 4crawler BL | SAW's | OME 890's | OME N86C Shocks | 285 Nitto TG's
osker fenix is offline
Old 03-26-2008, 12:28 AM   #2 (permalink)
hiloracerboy84's Avatar
dont know about the saw deal, but just spray all the bolts with pb blaster or similar starting now, and it should be trouble free come this weekend. may want to have a breaker bar handy, and things will be 10X quicker w/ an impact.
__________________
1997 4WD SR5 V6 AT
gray wire, Deckplate, ISR, electric fan, 881 w/topout, 891, 2" 4crawler, 16x8 EA's, 285's, murano/sti w/ 50w of HIDeeeee
hiloracerboy84 is offline
Old 03-26-2008, 12:30 AM   #3 (permalink)
j-man's Avatar
on all my runners - i didnt have to mess with anything. Just pop off the wheel, unscrew the sway bar nut, unscrew the 3 bolts on top of the shock holder, unscrew and take out the nut/bolt at the bottom holding it all in, and presto - its out. if you crank up your saws before installation, they can sometimes be a pain to get in, so i use a bottle jack and position it on top between the a-arm and teh fender well and crank it down enough to slip the saw in there. good luck - each side takes me about 6 min total now.
The rear on the other hand - the shock is the biggest pain out of everything to remove/install. IT requires u to contort your hand/arm enough to get at the nut on top of the shock to unscrew it. THe coil is easy - just remove your sway bar nut, let the axle dangle, and wiggle it and should pop right out. installation is just as easy.
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed
99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear
98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m
97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
http://community.webshots.com/user/bajaroadtrain
j-man is offline
Old 03-26-2008, 12:37 AM   #4 (permalink)
BornChaos's Avatar
Send a message via AIM to BornChaos
A few tips in removing the rear shocks: Leave the lower shock mount connected as serves as an assistant in holding the shock in place. Use a type of wrench that will grab the shock body. If you intend to discard of the shocks (as in not sell them or save them) a Chain Wrench works well. Chain Wrenches might be somewhat expensive. I would recommend using a Belt Wrench, which can be had at sears for like 10 bucks. The belt wrench won't damage the shock body. Use the wrench to grab the shock body while you wrench the nut from the top. It's a bitch. Oh yeah, remove your spare for more room to work back there. Use lots of PB Blaster prior to doing this so it will make your life easier. You may also be able to tighten the wrench around the shock body, then let it turn until the wrench hits something that will hold the wrench in place while you use both hands to turn your ratchet to losen the nut up at the top.
For the front: Install the SAW coilovers uncranked, then with the vehicle OFF the ground, use the spanner wrench to dial in the height you want. I hear this can get kind of tough, so take your time. I have never used or seen the spanner wrench that comes with the kit in person, but if its at all possible, try to find something that will fit over the wrench and effectively extend it, giving you more leverage.
Those are my ideas
__________________
-Ned
1997 4Runner SR5 3.4L 4x4 | OME/TRD Lift | Kenwood KDCX789, polk db650 speakers | 265/75/16 Pro Comp MT | American Racing Baja 16x8 | Yakima Racks | S.S. diff drops | WabFab Discos | Polyeurethane bushings all over the place
BornChaos is offline
Old 03-26-2008, 12:57 AM   #5 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
here's a good write up to remove the front struts
http://www.4rnr.net/suspension.html
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 03-26-2008, 05:43 PM   #6 (permalink)
sweet thanks my fellow yotatechers and californians. Thanks for telling me about the swaybar bolts i didnt even think of that. Im gonna be installing this at my friends dealership so we'll have impacts and a rack, so hopefully that'll make our lives easier...right now im just really fearing those rear shocks.
Anyone know about those brakelines?
__________________
-Brandon
Old 03-26-2008, 09:00 PM   #7 (permalink)
anyone know off hand what size socket i need for the top bolt of the rear shock?
__________________
-Brandon
Old 03-26-2008, 09:19 PM   #8 (permalink)
Dare44's Avatar
i just did it, most everything was 17mm, 19mm, and 14mm, i think it was 19 but dont quote me on that. an extra set of hands it the best tool to have, took me a while to get mine on, the front didnt just slide on mine tho took alot of forcing and beating to get the front coils in, the jack between the fender and the upper a-arm is wat i ended up doing and that worked the best. took about a half hour a side after i figured out how to do it, and then the rear took like 40mins but that was mostly spent trying to get my track bars back in place,which i shouldnt have taken off anyway.
__________________
1997 Toyota 4x4 SR5 4runner
3.4 auto
Toytec 3 inch coil spring Lift
Custom Front bumper
Trail Gear Rock Sliders
Modified Stock skid plates
Maxxis Bighorn M/T's / Goodyear Wrangler TD's
Amp Custom Rims
Cobra CB, 5ft Firestik
http://www.cardomain.com/ride/3008195
Near Future List
Rear Bumper
Lockers
1st Gen Roll Bar
Winning the Lottery?
Dare44 is offline
Old 03-26-2008, 09:53 PM   #9 (permalink)
dude nice another californian! what about your panhard bracket did you install one of those? was it pretty straight forward?
__________________
-Brandon
Old 07-09-2008, 03:24 AM   #10 (permalink)
Quote:
Exactly what I did and what a relief it was to finally get that taken care of. This is why Yotatech is such a great site/forum. Tons of posts that help out in explaining the details one may not ever find in just reading the vague step-by-step instructions in a manual.
__________________
2000 4Runner V-6 3.4L FI 5VZ-FE, 5-spd manual, NGK plugs/wires, Amsoil: filter/engine oil 5w-30, tranmission/transfer case 75w-90 GL-4, rear diff 80w-90 GL-5, front 75w-90 GL-5, Trekmasters/OME 890 in the rear, Centric disc rotors w/ Hawk LTS pads, slowly upgrading
seized, stripped or broken, impossible access to hard-to-reach places, discovering I don't have the tool/part needed to finish the job, in the middle of the job....PRICELESS & worth it all once achieved!
75w90mantraN is offline
Old 07-09-2008, 07:59 AM   #11 (permalink)
TC4RNR's Avatar
Quote:
take the spare tire out first. that will give you some extra space.
you can do it all by yourself, specially while the rear coils and shocks are out. if it's kinda stiff to when putting back the panhard bar, use a racheting tie down to pull it in little by little.
__________________
http://i172.photobucket.com/albums/w...gca/agreed.jpg
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. LC80 wheels, SS 1.2 lift, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, roof busket, hitch mount tire carrier, Tundra Brakes, Brembo rotors, BudBuilt skid, Lightforce 240 Blitz, PiAA HID, Stubb's HD-SKO sliders. ScanGauge II
04 4Runner SR5 V6 4WD. 265/75/16 BFG KO, FJC coils and silver Bilstein shocks, Scion H/U.
TC4RNR is offline
Old 07-09-2008, 08:42 AM   #12 (permalink)
MATT0404's Avatar
Old thread.
__________________
99 4Runner 4x4
3.4
5 speed
E-Locker
SAW 2.0 Coilovers
LC coils and shocks
1" 4 Crawler Body Lift
1" Diff drop
SS adjustable trac bar
Addco front/rear sway bars
285/75/16 Maxxis Bighorns
MATT0404 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
SS#7 install tips Henrythewound 95.5-2004 Tacomas & 96-2002 4Runners 10 09-07-2007 12:04 PM
clutch install tips. DN1911 86-95 Trucks & 4Runners 2 07-10-2006 05:54 PM
Finally got bushwackers any install tips? skshepherd 95.5-2004 Tacomas & 96-2002 4Runners 5 05-24-2004 09:44 AM
93' Clutch Install Tips ? jsrusse11 95.5-2004 Tacomas & 96-2002 4Runners 1 04-20-2004 01:10 PM
22R Carb install, Any tips? Plays_with_Toys Maintenance & Repair Archives 1 05-18-2003 11:32 AM
2009 InternetBrands, Inc.
