Any cure for noisy rear coil springs?
Old 06-16-2004, 08:23 AM
Jboy's Avatar
My passenger rear coil spring is really noisy. I have the stock rubber isolator/bumpstop in there. Why would my spring make a metal rattling noise when hitting dips or shaking it by hand. My rear passenger shock, Bilstein, is shot to. Oil leaking from seals, but this wouldn`t have anything to do with the noise from spring would it?
Old 06-16-2004, 08:48 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Are you sure the noise is from the spring and not the "dead" shock? I'v had many instances over the years of a bad shock or one w/loose hardware sounding as if the suspension was about to go belly-up.
Old 06-16-2004, 08:58 AM
Jboy's Avatar
In parking, I grabbed the spring and shook it and it made that same noise I hear when driving. There is some play but very little. I would think the spring would be in there tight with the weight of the runner keeping it in place but that is not the case. Even if I removed the isolator it shouldn`t make any metal to metal noise, would it?
I also moved the rear by jumping on bumper to test the shocks and no noise.
88sasturbotoy
08-11-2015 01:56 AM
terminator
07-27-2015 07:13 PM
Massmayhem247
07-24-2015 12:07 PM
Nickdigg
07-07-2015 06:04 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Any cure for noisy rear coil springs?
