antenna, timing belt and running board questions
Old 03-05-2006, 09:09 AM
designer_jeff's Avatar
Question antenna, timing belt and running board questions
My power antenna broke and I tried to access the power unit behind the right front wheel. How do I get the plastic shield off? There are some plastic buttons holding it on and I can't figure out how to remove them. Also I have running boards not molded into the fender flares. How do I remove the front cap that wraps around the front inner fender. I removed the 2 screws inside the wheel well but it still will not come off.
Also I need to replace the timing belt (V6) 117,000 miles what other items should be replaced while doing this repair and about how long will it take? If I start Saturday morning will I be done by Sunday afternoon? This is the first time I am attemping to change the timing belt.
Thanks for your help. Jeff
Old 03-05-2006, 09:52 AM
FUZION's Avatar
You just pry the shield off,
4runner has a timing chain not a belt. I have 160 and I havent changed it yet.
Old 03-05-2006, 10:10 AM
Do you replace the plastic buttons then with new? Can I get them from Autozone? The closest Toyota dealer is 40 miles away. Jeff
Old 03-05-2006, 10:15 AM
FUZION's Avatar
Mine didnt break, but if you do have to replace them definitely autozone NOT the dealer.
Old 03-05-2006, 10:25 AM
Thanks again, mine happens to be black as well. BTW my 4Runner has the rear end squats. I know of the recall and had that done but the rear is not level with the front. There was some one selling a leveling kit, do you know who it was?
Jeff
Old 03-05-2006, 10:29 AM
FUZION's Avatar
the recall was on the 96. Mine doesnt sag but depending on how much it sags you can just purchase a spacer lift to even it out. About $85. A leveling kit $$$$
Old 03-05-2006, 10:37 AM
Where do you get a spacer lift?
Old 03-05-2006, 10:56 AM
Bob_98SR5's Avatar
jeff,
please check your PM box
bob
Old 03-05-2006, 12:01 PM
habanero's Avatar
My '96 3.4 V6 4runner definitely has a timing belt. Search timing belts for more info. I pried carefully on the button that I needed to remove to get to the antenna motor-you don't have to take the whole shield down, just enough to get to what you need-and reused it. Mostly it was bolts, 10mm if I remember right.
Old 03-05-2006, 12:41 PM
Paul H.'s Avatar
3rd Gen v6's have a timing belt not a chain. When you change the belt, also replace all of the drive belts and the water pump. As for time, it depends on how mechanically inclined you are.
Old 03-05-2006, 02:36 PM
FUZION's Avatar
oops didnt read it was a V6, my bad, i was thinking of my 4 cyl
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
B. Graves
07-03-2015 04:10 AM
crazypaint
06-23-2015 03:27 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: antenna, timing belt and running board questions
