Another rear hatch/trunk lock question
Old 05-28-2006, 07:55 PM
TheDarkKnight's Avatar
Hi All,
The lock for the trunk on my 98 has finally died.
I think that the latch mechanism has gotten so rusty that the spring no longer works (or broke) :pat: . When I try to close the hatch, the latch mechanism does not get out of the way, thus it hits the stricker and the hatch just bounces back.
I am wondering where I can find a used latch (cheap), to replace mine with.
(Even better , if there is someone close to Michigan that can give me a deal on the entire rear hatch, please let me know).
Thank you!!
tdk
Old 05-28-2006, 10:04 PM
CdTriX's Avatar
hahahah i have the same problem hahaha
only way is to use you're key... to put the latch back i just don't bother with the latch.. and just lower the window whenever i need something
edit: my dad has tried everything to fix it.. lube, grease, taking it apart and putting it back together... can't get it to latch properly...
Old 05-29-2006, 12:48 AM
Bob_98SR5's Avatar
search "broken rear latch" or variations thereof. there are numerous threads on it
Old 05-30-2006, 09:35 AM
Thanks Bob,
I will check it out... this weekend?
tdk.
Old 07-21-2011, 08:30 AM
y2kltdsport's Avatar
rear hatch latch fixed...P.T.L.
after reading through the threads, it sounded like i was going to need a new latch mechanism, ( mine would not latch and hold door shut).
I took it all apart to look things over, and was surprised at how well everything looked in there( close to 300K on a 2000 ltd) and in "way too much salt on the roads in wintertime MN" VERY surprised.
after kind of figuring out how it all works, I looked at the latch and started playing with it,it would move freely back and foth but woundn't stay closed, I noticed a little lever on top of the unit that was very stiff when I tried to see if it would move, after working it with some "PB" it was moving freely and would snap back into position,which it wasn't doing. so I lubed it up after working it back and forth with a ton of "PB" and now it all works perfectly P.T.L.!!!
the pics show the latch mech. you have to pull back a rubber gasket on the top to see the parts that I dealt with, the lever that was the problem is in the last pic with the end of a sharpie kind of pointing at it, sorry about the blurry pics.hope this can save someone some money like it did me.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: Another rear hatch/trunk lock question
