Another OME/Tire size question.
Since I don't have a definate answer to this, time to start a new thread on it.
After I install my OME suspension next week, I'll be on the hunt for tires. Only problem is, I'm not sure what size.
I'm looking for the largest size that won't rub and will fit on 15x7 wheels. I'm not changing the wheels, so I have to accommodate them
I was thinking 32x11.5, but I'm not sure if this is the best option. I want your opinion before I finalize it.
Suspension specs are as follows:
OME Regualr F&R Shocks
OME HD Rear Coils
I should expect 1.5" to 2" of gained height.
Also, should I invest in SAW 25mm torsion bars for the front?
OME HD Rear Coils
OME HD Rear Coils
OME HD Rear Coils
Originally Posted by waskillywabbit
I would think that 285/75/16 would be fine with no rubbing if you do some pinch weld bashing and a bit of fender well trimming in the appropriate spots.
smilen724
13
11-08-2015 04:11 PM
