Amsoil product info for 2nd gen 4runner
Old 12-01-2003, 05:40 PM
CMD93's Avatar
I recieved this info from Amsoil today. I thought that it may be useful to some.
1993 TOYOTA 4-RUNNER 3.0L 6-cyl VIN Code P 3V-ZE
FILTERS
Oil Filter......SDF57
Air Filter......AF894
Fuel Filter......GF219
PCV Valve......HV85
Trans......TF96, 2WD
Trans......TF97, 4WD
BOSCH WIPER BLADES
Driver side......B40916
Passenger side......B40916
Rear window......B40913
CHASSIS LUBRICATION
Four-wheel drive
8 Fittings, 4 Plugs..........LM
Series 2000 Synthetic Racing Grease (GRG)
Synthetic GH Series Heavy-Duty EP Grease (GHB, GHD)
Synthetic GL Series Multi-Purpose EP Grease (GLA, GLB, GLC)
Two-wheel drive
0 Fittings, 4 Plugs..........LM
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil (TSO)
SAE 5W-30 SYNTHETIC MOTOR OIL (ASL)
Synthetic XL-7500 Motor Oil (XLF, XLM, XLT)
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD)
Grade 2......API*
Above 0°F......10W-30
Below 50°F......5W-30
Manual Transmission,.....GL-5
All temps......75W-90
Series 2000 Synthetic Gear Lube (TGR)
Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO)
Manual Transmission,.....GL-4
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid (ATF)
Differential, Front .....GL-5
Below -18°C......80W, 80W-90
Differential, Rear .....GL-5
Transfer Case,At.....AF3
Transfer Case,Mt.....GL-4
75W-90
Series 2000 Synthetic Gear Lube (TGO)
Transfer Case,Mt.....GL-5
75W-90
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
CAPACITIES
Engine, 2WDwith filter..........4.6 quarts[1]
Engine, 4WDwith filter..........4.8 quarts[1]
Cooling System, Initial Fill..........11.0 quarts
Automatic Transmission, 2WD Initial Fill..........1.7 quarts[2]
Automatic Transmission, 4WD Initial Fill..........4.8 quarts[2]
Automatic Transmission, Total Fill..........11.0 quarts
Manual Transmission, 4WD G58 trans..........8.2 pints
Manual Transmission, 4WD others..........6.3 pints
Manual Transmission, 2WD R from 5/94..........5.5 pints
Manual Transmission, 4WD from 6/94..........4.6 pints
Manual Transmission, 2WD G57 trans..........4.6 pints
Manual Transmission, 2WD R to 4/94..........6.3 pints
Manual Transmission, 2WD others..........5.1 pints
Differential, with adrd Front..........4.0 pints
Differential, witho adrd Front..........3.4 pints
Differential, Rear..........4.6 pints
Transfer Case,AT..........1.7 pints
Transfer Case,MT: G56, R150..........2.3 pints
Transfer Case,Mt: Others..........3.4 pints
1. Capacity shown includes filter. After refill check oil level
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....18 ft-lbs
Manual Transmission
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
Manual Transmission W46, W55-56
Fill Plug.....30 ft-lbs
Drain Plug.....30 ft-lbs
Maybe some already know this stuff, but I found it useful.
Chris
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Amsoil product info for 2nd gen 4runner
