amsoil engine flush -any exp?
Old 05-20-2003, 08:27 AM
amorphous's Avatar
was kicking around doing this to both my 4runner and my Camry...anyone use it>? is it drop in and go or is it more complex?
thanks in advance,
aaron
Old 05-20-2003, 09:05 AM
tomstin's Avatar
I did it on my Civic with 90k miles, ran it, drained in and replaced the oil with Amsoil Sythetic about six months ago. Changed the oil after 5k, it looked a little dirty, this change looks like it's staying cleaner. I guess the cleaner loosened everything up and it took a change to clear it out.
Old 05-20-2003, 09:10 AM
SLC Punk's Avatar
Is this safe for engines that have a turbo on it?
Old 05-20-2003, 10:11 AM
amorphous's Avatar
so what's the process?
hey tomstin,
what's the process on this? do you run it for a while? (maybe I should email amsoil *duh!*)
thanks,
aaron
Old 05-20-2003, 10:29 AM
Citykid's Avatar
Just do it. It's very easy & Amsoil recomends it. It is only a couple of bucks anyway.
Old 05-20-2003, 11:49 AM
Not knowing the first thing about this product, I have a 4runner with 85k on the clock now and this sounds like it might be a beneficial thing to do to ensure the continued health of my engine which is running great - I'd like to keep it that way.
I also just got an oil change (about 20 miles ago actually). Should I use something like this now and let it move all that gunk through for another 3k miles, or wait until I'm near the end of that before I get another change and go for it then?
I very much dislike the idea of having free particles floating around in the oil, but maybe this stuff needs some time to do it's thing...
Old 05-20-2003, 12:19 PM
amorphous's Avatar
good Q
that's a good question...I've posed that to AMSOIL...i letcha know what they say....
a
Old 05-20-2003, 02:50 PM
Thumbs up
i have owned 4 toyota trucks.all of them i pushed over 300+ miles.i just tryed auto-rx.stuff works good! it helps get a lot of slug or gel out of my engines.check it out.
http://www.auto-rx.com/
Old 05-20-2003, 03:14 PM
Paul H.'s Avatar
I did this recently to my 4Runner. Here is what I did. I drained about a quart of oil and then poured in the cleaner. Then I ran the engine for about 20 minutes. DO NOT DRIVE THE VEHICLE WITH THIS STUFF IN YOUR ENGINE. Drain the oil and change the filter. Refill with whatever you choose and your done. Hope this helps. BTW these instructions are on the container.
icentropy
09-16-2020 02:47 PM
the1998sr5
15
07-14-2020 08:35 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: amsoil engine flush -any exp?
