View Poll Results: What color combination for my Aisin hubs
Silver Body, Silver or Polished Cap and Dial
7.41%
Silver Body, Black Cap, Dark Blue Dial
22.22%
Black Body, Black Cap, Dark Blue Dial
18.52%
Just put the damn things on and call it a day!!
14
51.85%
Voters: 27. You may not vote on this poll
Aisin Hub Painting
Old 02-24-2003, 07:24 PM
  #61
4x4CPOSEADOG's Avatar
Thanks Skydigger for the compliment. I put a lot of hours on them, stripping, priming, coating, and clear coating to get them as sharp as possible.
Old 02-24-2003, 07:38 PM
  #62
Cebby's Avatar
Originally posted by 4x4CPOSEADOG
I was thinking to get the stainless bolts too but I had a hard time finding them. I went to Lowe's and Home Depot but no luck so I went to the stealer. Where did you get yours?
A place called "Metric Screw and Fastener" in Allison Park, PA
Why did you get talked out by the forum and what was the reason?
I think I just let majority rule and I didn't have but a few votes for the yellow. I had them painted yellow, but the paint I used didn't give me good coverage, so I stripped them again. Maybe I'll try again someday...
My oldest hands me wrenches, but he gets easily distracted, so it's a little too much work to get anything done. For now...
Old 02-24-2003, 07:50 PM
  #63
See my runner is green and if combined with yellow= mello yello.
Hey Cebby, when your paint start to fade then switch to yellow and give them four coats, don't forget at least three coats of primer and two coats of clear coat. I baked mine in the oven for two hours with 170 F.
Well I guess I have to stick with the OEM bolts since I can't get stainless.
Hey you know what I do if my son get distracted. I always called the wife for assistance, and I always get that look "it is not my job" Oh well.
Noel
Old 02-25-2003, 04:37 AM
  #64
Cebby's Avatar
I get that same look!!!!
Old 02-25-2003, 06:09 AM
  #65
Hokiez97's Avatar
Stainless Bolts
Hey 4x4CPOSEADOG,
Try checking at lowes in the hardware section.
They have some bin boxes with metric and standard bolts. They sell them 5 to a pack so you will have a couple of extra ones. I picked mine up from the lowes in Newport News. I welive they are M6 sizing. Just take one of yours in, and since they dont have a thread checker, open one of their packs of m6 nuts and try it. Stores that sell bolts and nuts always complain about open packages, but its their own fault..
Of course they had the bolts but were out of the washers so I went with 1/4 stainless washers. Slightly big but not too big.
That color is sharp and thanks for the size of the holesaw so that I can cut the hole out of my caps.
I will be painting mine when it gets warm.
GREAT JOB!
Mike
Old 02-25-2003, 06:24 AM
  #66
Cebby's Avatar
Bolt Size
M6 is correct. The thread is 1.0. I got 20mm bolts, but the Toy ones are about 18mm. The 20's worked fine. (FYI - 19mm=3/4")
Mine looked so bad, I changed them in the parking lot of the fastener distributor!:eek:
Old 03-27-2004, 05:40 AM
  #67
Cebby's Avatar
Back to the top for an old thread...
Well, two winters have not been kind to my hub paint job. The outer ring has been beat up from having the wheels off multiple times and the front rotors replaced since going to the manual hubs. The dials concern me, because they look just like the paint "peeled off" (after a year and a half!!). BTW, I never "baked" the paint on in the oven...
Well, as luck would have it, an old friend of mine now has the ability to powdercoat. Has anyone powdercoated the dial parts? I know I'd need to mask the inside somehow. I'd think it would hold up pretty well.
Any thoughts?
Old 03-29-2004, 02:19 PM
  #68
Cebby's Avatar
Anyone??
Old 03-29-2004, 02:29 PM
  #69
Skydigger's Avatar
Originally Posted by Cebby
Anyone??
Go for it man! You can be the first!
I don't see why that wouldn't work as long as you prevent the powder-coat from getting on the vital parts.
Warren
Old 10-11-2004, 05:41 PM
  #70
Sludge's Avatar
Cebby
Did you get your hubs powder coated?
Old 10-11-2004, 06:52 PM
  #71
AW1090's Avatar
I was chattin with him a while back and I don't think he did....too much trouble. He'll probably let you know for sure here in a bit. I was talking to him a while back when I got my hubs. I was thinking about powder coating, but just sprayed 3 times and baked them....they look great so I'm just gonna see how they hold up.
Old 10-12-2004, 07:04 AM
  #72
Cebby's Avatar
Originally Posted by FireFighter
Cebby
No - I'm going to spray and bake them. Too much of a PIA to keep the powder off the surrfaces that should not have s finish on them.
Old 09-03-2007, 02:03 PM
  #73
xcmountain80's Avatar
Super old post but heres what I did. Just rattle can and easy to touch up.
Aaron
Old 09-03-2007, 02:17 PM
  #74
Trumpfan's Avatar
looks good, didn't like the red knob?
Old 09-03-2007, 02:57 PM
  #75
The newer 96+ come as you see on the right, black and silver. I matched the face to the rim color I'm using on one set of wheels then blacked the bolt, and re-silvered the center. I don't think the black nuts will hold up to long.
Aaron
Old 09-03-2007, 03:48 PM
  #76
Trumpfan's Avatar
I see, should look sharp then.
G-off
12-29-2015 12:44 PM
stanz
10-30-2015 10:33 AM
mxdw88
09-20-2015 03:13 AM
sonorn67
09-19-2015 05:39 PM
Quick Reply: Aisin Hub Painting
