Air Intake Mod, Air Intake Temp Sensor Mod
Old Nov 15, 2004 | 06:53 PM
BOSTON4RUNNER's Avatar
who has modified air boxes, intakes?
i made one the other day, came out pretty good
i have a bunch of the tubing to duplicate the mod
i was thinking of buying one of those diode, that plug into the air intake temp sensor, anyone on here have one? they are all over ebay,,are they worth 5 hp maybe?
let me know
pics of my air intake is in my signature
thanks in advance for your thoughts on the ait thing
tim
Old Nov 15, 2004 | 07:23 PM
kevin444's Avatar
I can vouch that maybe 80% of us here dont use the stock airbox ahhaah!
Old Nov 16, 2004 | 04:22 AM
anyone do the air intake temp sensor modification?
thanks, tim
Old Nov 16, 2004 | 04:50 AM
drkgypsy's Avatar
From: Grew up in Santa Clarita/San Fernando Valley's...now in Washington State
What does the stock air box setup look like agian???? Hahahaha
Old Nov 16, 2004 | 05:13 AM
jimbo74's Avatar
the IAT mod has been discussed on this board and other vehicle boards, and the conscenus is that its a waste of time, money, and might possibly do damage to your truck. the reasoning behind that is supposedly, it makes the engine think that it is running lean, so it dumps more gas into the cc is the theory, as the computer will try to compensate for that...... however in the real world, the computer knows what is going on and just bypasses that circuit all together when this happens due to the fact it thinks something is broken or tampered with, and will still run, but not at optimized performance
Old Nov 16, 2004 | 05:22 AM
rimpainter.com's Avatar
IAT mod
https://www.yotatech.com/forums/show...=potentiometer
I like your custom piping, but I would never run an open cone filter like that. If I only drove on the street, then maybe. But most of us off-road here so that is actually a very risky design. Both from a dirt and water standpoint.
Personally, I would run your custom piping to the stock airbox and do the deckplate mod with an Amsoil filter. My .02.
Nice work on the piping though.
Old Nov 16, 2004 | 05:44 AM
truck is mainly street driven
eventually might convert to a full on snorkel
I am trying not to go crazy on the truck....but it is a challenge not to
Old Nov 17, 2004 | 05:40 AM
is this mod pure BS or will it work?
anyone know what type of diode/resistor it is
and into which port it should be plugged into? I would like to go to the local electronics store and pick one up.
any ideas on this? thanks
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Nov 17, 2004 | 05:54 AM
Did you read this?
MTL_4runner's Avatar
It does work but you can end up clogging up your O2 sensor much faster and again you will get worse gas mileage.
Just do the deckplate and amsoil filter like most have done and you'll get quite good results
Old Nov 17, 2004 | 06:01 AM
already put a new air intake in the truck,,,,pics are on my webpage
do you know what type of diode/resistor that should be used?
thanks
Old Nov 17, 2004 | 06:35 AM
thanks
It is all in here:
Old Nov 17, 2004 | 06:41 AM
i just want to do it the simple way, insert diode/resistor into plug end
i dont want to do the dial, adjuster and all that other stuff
thanks, though
Old Nov 17, 2004 | 06:47 AM
thanks, though
It is not a one size fits all resistor value and that is why some tuning is involved and why you need a potentiometer (variable resistor). You find the right value for your truck and then get the appropriate value resistor if you want it to be permanent (otherwise just leave the potentiometer in place). Each truck is different so you need to do some work to get this one. The ones they sell on ebay suck bigtime for exactly this reason.
Old Nov 17, 2004 | 07:00 AM
thanks, appreciate the detail in your response
so the ebay ones suck
might just wait and find a supercharger
mandrel 2.5 exhaust going in saturday
I will post pics
the1998sr5
15
Jul 14, 2020 08:35 PM
Massmayhem247
Jul 18, 2015 05:46 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
