Air horn upgrade
Old 01-27-2012, 06:40 PM
Clownmeat's Avatar
Air horn upgrade
Another thing I am working on at the moment is getting rid of the stock sissy embarrassing horn. It doesn't quite reflect the image of the vehicle when it makes a laughable little beep. So I got a Hadley air horn set off a cement truck, just need a switch and some lines, turn it up to ~120 psi, good to go.
Old 01-27-2012, 07:05 PM
Clownmeat's Avatar
Got the horns all refurbished, hooked them up to the compressor at work, holy crap they are loud!
Old 01-27-2012, 07:19 PM
madbomber08's Avatar
This is going to be epic. Are you going to wire the air horn so it goes off when you hit the center of the steering wheel or are you going have a separate switch? Definitely definitely post a sound clip once these are done!
Old 01-27-2012, 07:29 PM
Clownmeat's Avatar
Yes. Removed the stock horns and will wire the air solenoid to the stock harness.
Old 01-27-2012, 07:47 PM
Clownmeat's Avatar
The air/electric solenoid.
Old 01-27-2012, 08:24 PM
Clownmeat's Avatar
Their new home.
Old 01-28-2012, 03:42 AM
Bassmastry101's Avatar
Freaking awesome, I like the way it tucks behind everything. Great work!
Old 01-28-2012, 07:54 AM
mt_goat's Avatar
Nice horns! What are you using for a compressed air source?
Old 01-28-2012, 09:57 AM
Clownmeat's Avatar
Old 01-28-2012, 12:44 PM
mt_goat's Avatar
Better than 2000 words
Old 01-28-2012, 12:48 PM
Clownmeat's Avatar
Yeah I like pictures, reminds me I need to get a higher psi gauge.
Old 01-28-2012, 12:54 PM
mt_goat's Avatar
What brand compressor is that? How often does it kick on if you don't blow the horn (or is it a manual switch)?
Old 01-28-2012, 01:00 PM
Clownmeat's Avatar
Dont remember the brand and the label is faded. I have it wired on a switch, but after it's full it doesn't come back on for a long time because nothing is hooked to it at the moment.
Old 01-28-2012, 01:20 PM
Clownmeat's Avatar
Got the horn mounted and it's on the way back together.
Old 01-28-2012, 03:46 PM
gdstock's Avatar
Those look pretty good!
Old 01-29-2012, 08:21 AM
mt_goat's Avatar
I bet they sound even better than they look
Old 01-29-2012, 12:24 PM
Rock Slide's Avatar
Nice work. Is there any delay from the time you depress the center of the steering wheel, to the horns sounding off?
Old 01-29-2012, 05:09 PM
Black_1985_SR5's Avatar
That's sweet but I would want both I like the idea of "meep meep" and if they don't listen you follow with the air horns
Old 01-29-2012, 05:16 PM
GranVille-4crawler's Avatar
I'm runnin 2 kleinn horns I fricken love them. I dont know if I like where you have your compressor, it's best to keep those things away from exposure to moisture, or atleast I do. Clean setup with the placement behind the bumper!
Old 01-30-2012, 07:04 AM
Clownmeat's Avatar
The solenoid is about 2 inches from the horn, so I doubt there will be.
Quick Reply: Air horn upgrade
