Air Conditioner making mice sounds
Old 08-09-2005, 01:28 PM
Nick Cuban's Avatar
just recently the a/c has been making squeaking sounds... is this a common problem in 01 tacomas?
Old 08-10-2005, 04:46 AM
SloPoke's Avatar
From where? The compressor, the belt, the blower fan, the vents?
or (if your not really sure)
Is it in the engine compartment or the cab?
Tacomas do experience issues with the AC idler pully bearing (usually from excessive mud running) so if it's in the engine compartment, that's most likely the culprit. About 6-8 bux at a local bearing house or 27-30 at the stealer. Hate to elaborate more in case that's not it. Super easy DIY fix tho so no worries there.
Leme know.
Old 08-10-2005, 03:46 PM
Nick Cuban's Avatar
i only hear it in the cab... although i have not listened for it outside the truck but i ahvent noticed it either outside the truck. it seems like its coming from the vent on the passenger side against the window.
Old 08-10-2005, 06:13 PM
SloPoke's Avatar
Ahhhh, definately not the bearing then.
The infamous duct wistle. I remember seeing a write up on that somewhere many moons ago. IIRC it has something to do with the blower wheel or some bushing on it's shaft or something. Sorry, not much help I know.
At any rate...good luck!
Old 08-10-2005, 06:16 PM
89macrunner's Avatar
my A\C makes funny noises
but than again i RARELY use it
Old 08-10-2005, 06:34 PM
Nick Cuban's Avatar
you are crazy, mines always on regardless of what its like outside. i like constant airflow and im in FL so its always 254864396345 degrees outside
MO transplant
04-23-2023 11:58 AM
nanhodges2733
05-29-2020 03:28 PM
Eggslinger
06-08-2019 03:32 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Air Conditioner making mice sounds
