Aftermarket leather seats
when you do the door panel inserts, first remove the panel off the door it makes it a lot easier. Then do a dri fit first, meaning stuff them into the door and see where you need to cut it. The only tricky part I found was when reinstalling the door panel was the place where you pull the handle to open the door. You have to cut the foam correctly here b/c it slides back int place kind of offset from what it appears to be. I'm sure I'm not explaining this very well ...... uummm dry fit the door, then when your cutting the foam/leather for the door handle release test it out first by putting the door panel back on the door. and then you'll see what I am talking about. .. hopefully.
oh when your doing the headrest don't try too stretch the leather over the headrest, instead bend the headrest in, one side at a time and squeeze them into the leather.
also if you've ever considered getting seat heaters this would be the time to do it, since you already have the leather off.
I'm almost done, just gotta do the back half. I dont need to use the glue because the kit came with the actual replacement inserts with plastic backing meaning i just take out the old door panel insert and replace it with these ones, I guess they weren't kidding when they said this is a dealer option. I'm very happy with the results it looks so much better and color matches perfectly. Seats are a LOT firmer and it has so much more lateral support now. . I dont think I'd want to put down another $150 for heated seats since it never gets that cold around here and my truck is always garaged. I used hog ring pliers and hog rings and did it by the book. Wrinkles from shipping will straighten in a few days or more cuz it's winter. only part i have to glue is the bottom door handle below the inside door knob, the long C looking thing that snaps in. Doors are gonna be easy so tomorrow i'm looking at about 4hrs for 1 back seat and door panels. I'm gonna take it to my brother in law's shop to have him do the cutting, glueing, and fitting since tinters are better at it.: I'll post some pics when i'm done tomorrow hopefully. Thanks for all your concerns And about the headrests. They fit like a factory. No slacks or wrinkles! not like the ones i returned before(if you recall my last post bout a year ago)
#27
Sorry but I'm not completly done, I'm done with the seats but still have got to do the doors. I've done an initial fit over the door panels. and I just found out that my digicam is broken....sux but i'll find a way to get those pics up.
#28
well my camera is still out of battery, I took this with my phone camera. just a rough idea of what it looks like. http://community.webshots.com/s/imag...1WOIMCo_ph.jpg
#32
Originally posted by Vato Loco
Link doesn't work, this is what I got:
Forbidden
You don't have permission to access /s/image9/8/32/11/113383211WOIMCo_ph.jpg on this server.
Forbidden
Looks really good to me!
#33
ben 95M ur rig and mine looks almost identical! same color, rims, guards....haha nice! well mine's not limited but...with leather...very close to it hehe
#34
#37
Looks OEM , was it hard doing the seats?
#38
Here are a couple pics of my finished leather kit install:
http://groups.msn.com/2000SR5ToyotaT...oto&PhotoID=18
http://groups.msn.com/2000SR5ToyotaT...oto&PhotoID=19
#40
You did a real nice proffesional job. I did ny own the first time, but the second time I just let the proffessionals do it. They did a much nicer job with the doors then I had done
