Aftermarket 3.4 throttle body?
Old 04-27-2010, 09:13 PM
Nerologic's Avatar
As question states, is there an aftermarket one available?
I searched and got no where, or does any other toyota one work?
I want to see if there is a direct replacement (or something similar) before i spend money on a custom adapter or have my stock ported.
Thanks in advance guys...
Old 04-27-2010, 09:36 PM
914runner's Avatar
The only option I've ever heard of is boring the stock throttle body.
Old 04-29-2010, 01:04 PM
Nerologic's Avatar
Ya thats what i figured.
Thanks for your input, i am getting a whole blown motor just for the intake manifold and chain cover plastic.
I guess i will just have to bore that one out...
Old 06-16-2010, 05:34 AM
paynemw's Avatar
I wanted to ask the same thing. My question is: will the newer V8 engine Throttle Bodies fit on the 3.4 5VZ-FE intakes? What about porting the intake as well?
Old 06-19-2010, 10:24 PM
Nerologic's Avatar
I doubt it.
The pattern seems completely different.
I ended up having mine borred out to 64mm.
Old 06-20-2010, 05:33 AM
jdmaccord6's Avatar
did you notice any performance gains from it?
Old 06-20-2010, 07:26 AM
paynemw's Avatar
and how much did it cost you?
Old 06-20-2010, 08:26 PM
rimpainter.com's Avatar
Just bore it out yourself. Bore the front end to the butterfly valve (not past it) with a Dremel and various grinding/polishing attachments. No, I didn't notice any gains when mine was N/A so I'm not so sure it's worth the trouble.
You can get quite the intake set up going if you want to gain a little HP and some throttle response:
  • Deckplate or elbow mod ($15 or free)
  • ISR mod ($6)
  • TB coolant bypass mod (been running this one for years - no issues) - $5
  • TB bore (Free if you have a Dremel)
  • O Gasket mod ($6)
I still have (3) O Gaskets left from when I used to sell them. $6 shipped. Email me if you want one.
smthwsn357
12-04-2023 02:08 AM
montanatruck
02-26-2017 07:07 AM
jetpilot
08-15-2015 06:48 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Aftermarket 3.4 throttle body?
