After a balance, what would be considered alot of added weight on a wheel? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-12-2005, 03:16 PM   #1 (permalink)
LSUMatt1514's Avatar
Send a message via AIM to LSUMatt1514
I've got the other thread going about my warped rotors and vibration issues over 60+ miles per hour. I just checked the tires to see how much weight Limbaugh Toyota added to balance them. The front driver's side tire has 60g on it (2-30g weights) and the front passenger has 65g on it (1-30g and 1-35g). The two rears have only one weight each, but I can't make out how much they weigh. Both look to be smaller than either on the front. What's the deal? Is this an insanely large amount of weight on these front two or is it normal?
Matt
__________________
01' SR5 Sport Edition
Performance: Deck Plate w/ Amsoil Filter, ISR Mod, Dynomax Super Turbo w/ Pacesetter Tip
Exterior: Manik Brush Guard, Piaa 1000X, Piaa 540, OEM Skid Plate, Custom Sidemarkers, Clear Corners/Bumpers, H/L Alenzas, Thule Lappland Cargo Basket, Reverse Lamps, Silverstars
Interior: Stereo System, Dakota Digital Gauges, Coleman Inverter, Speedhut Gauges
http://community.webshots.com/user/phi1514
LSUMatt1514 is offline
Old 01-12-2005, 03:17 PM   #2 (permalink)
Make the vibration go away please!!!!!!!! I'm tired of wasting my time on this issue, but I'm afraid I'm going to end up back at Limbaugh Toyota bright and early Saturday morning and have them balance them over and over again until they get it right and after each time they do it, go test drive it on the interstate. Help!!!!!
Matt
__________________
Old 01-12-2005, 03:28 PM   #3 (permalink)
86toyota's Avatar
Where's tire boy when you need him....jimabena
You could switch the rear tires to the front, but those weights sound normal to me. I've had more weights on my swampers than that.
__________________
Gregg
86 yota extra cab, 4" Pro comp, 33's, cam, header,CF Dual friction, K&N, and so on... (SOLD)
89 toyota 4x4 flatbed
MY TRUCK
86toyota is offline
Old 01-12-2005, 03:36 PM   #4 (permalink)
Staff
4x4Fink's Avatar
Yeah, I'm used to having a bunch of weight on my mudders so I couldn't tell you if its a lot or not...wait for others to reply I guess.
Fink
4x4Fink is offline
Old 01-12-2005, 04:10 PM   #5 (permalink)
CBIguy's Avatar
that sounds very reasonable to me, 60 grams is only a little over 2 ounces, I have over 18oz on one of my 33" swampers, that's bad!!!! It is common practice however to put the tires that balance the best on the front, you might rotate and see??? You can also rotate the tire on the wheel to try to get it to balance better.
I've never seen wheel weights measured in grams in the U.S.??
CBIguy is offline
Old 01-12-2005, 05:18 PM   #6 (permalink)
Ironmike4x4's Avatar
Send a message via AIM to Ironmike4x4
I have no freaking idea. I'm a mechanic and have access to a wheel balancer, my 4Runner has a horrilbe vibration in it at 60+ miles per hour and I've balanced them several times. Everytime I balance it, its never true after so many miles on them. I've tried rotating them to even treadwear, different tire pressure, etc. I've even done my own alignment just to satisfy my mind and everything is dead on. If you find out then please let me know.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can.
Quote:
Originally Posted by Tofer
"ohhh you are one hot 4runner, look at that flex... oh yeahhhh"
Quote:
Originally Posted by YotaFun View Post
Yeah...
Teens these days...
(granted I am 19 ...
Ironmike4x4 is offline
Old 01-12-2005, 05:26 PM   #7 (permalink)
86toyota's Avatar
Do you torque your wheels down or use an impact wrench? There was a big thread about using a torque wrench to aleviate that problem. Also heard certain tires always vibrate. Just trying to help.
__________________
Gregg
MY TRUCK
86toyota is offline
Old 01-12-2005, 05:30 PM   #8 (permalink)
I have a torque stick and use the correct torque setting on my impact.
__________________
Yeah...
Teens these days...
Old 01-12-2005, 05:33 PM   #9 (permalink)
Senior Member
Send a message via AIM to jacksonpt
Your weights sound reasonable... the heavier the tire is, the more weight it's going to take to balance it. But also check the insie of the wheel - in cases where I need a ton of weight (3+ weights per wheel), my dealer will put 2 on one side and 2 on the other.
Is this the first time the tires have been balanced and you've seen vibration? How many miles do you have on the tires? What kind of tires are they (brand, model, size)? Some people have had issues with tires not even being round, so balancing doesn't do much. Have the dealer balance them, then give you the road force numbers. Anything over 16 (I think it's 16, perhaps it's 18) is generally considered unacceptable/defective for a typical road tire. Now, swampers probably don't apply because they are so heavy - I'm not sure about other MTs... but it might be something for you to look into.
__________________
Jackson - My Site
96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK!
My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving.
jacksonpt is offline
Old 01-12-2005, 06:31 PM   #10 (permalink)
Jackson,
When I first got a new set of tires about 4 months ago, I bought 265/75/16 Dueler Revo A/Ts and they vibrated like crazy. I returned them and got a set of 265/75/16 Michelin Cross Terrains. The vibration issue really didn't start until I put the Revos on, and now it won't go away. The highest road force number that I've got on the Michelins is a 14 and that is very acceptable. Unacceptable is anything above 30 from what I've heard. These Michelins have less than 1000 miles on them and are supposed to be the top of the line. That's why I chunked the Revos because I orginally thought that they were what was causing the vibration. Guess not. The road force balancer would have found any wheel that was not true and/or damaged and would have found an out of round tire and neither place (A&R or Limbaugh) have said anything about one of the tires being out of round. I don't know what the answer is, but from all the research that I've done on Yotatech, this sounds like a very common problem, some more easily solved than others.
Matt
__________________
Old 01-12-2005, 06:32 PM   #11 (permalink)
BTW, the steering wheel doesn't shake nearly as much at 60+ miles per hour as it did before I had the rotors replaced yesterday, but the vibration can still be felt in the seat and can be seen by looking over at the passenger seat or the driver's side sun visor.
Matt
__________________
Old 01-12-2005, 07:01 PM   #12 (permalink)
Brendan's Avatar
Send a message via MSN to Brendan
perhaps the driveshaft requires balancing, but if it started as soon as the tires were replaced, i would suspect something else. bent wheel(s) maybe? have someone drive beside you and watch your wheels spin as you drive.
__________________
1992 "Truck"
1978 Land Cruiser FJ40
pig and elephant DNA just won't splice :(
***DO NOT CLICK HERE***
Brendan is offline
Old 01-12-2005, 07:11 PM   #13 (permalink)
man you have had a crappy time with the whole new tire issue.
You are sure it is not an axel or driveshaft issue?
keep us updated
__________________
Carsten
99 4runner SR5 4x4 5spd
Roadtripr is offline
Old 01-12-2005, 07:22 PM   #14 (permalink)
stevrock's Avatar
Send a message via MSN to stevrock
How's about an alignment?
__________________
-Steve H.
88 4Runner: 22RE, 5 speed, soft top, 3" body lift
Quote:
Originally Posted by Flygtenstein
I have yet to meet a woman, no matter how physically beautiful, who was purely pleased to be naked. Maybe it was my shadow peering in the window, but I digress.
stevrock is offline
Old 01-12-2005, 07:32 PM   #15 (permalink)
The alignment is fine. It may be ever so slightly off, but definitely not bad. I'll probably try to get that done this weekend as well, but I know that's not what's causing it.
Matt
__________________
Old 01-12-2005, 08:28 PM   #16 (permalink)
Send a message via Yahoo to bamachem
Did you ever check your steering rack like I suggested? Something is snafu w/ the steering, ball joints, alignment, or possibly (but not likely) the driveshaft.
bamachem is offline
Old 01-13-2005, 04:57 AM   #17 (permalink)
Senior Member
Yea... my second thought was also play in the steering - perhaps tie rods?
__________________
Jackson - My Site
Old 01-13-2005, 05:03 AM   #18 (permalink)
that's EXACTLY what I told him about a month ago, but the dealer can't find anything wrong.
bamachem is offline
Old 01-13-2005, 05:08 AM   #19 (permalink)
Senior Member
I assume it's a competent dealer? I had one dealer tell me they couldn't do an alignment because there was too much play in my tie rod ends and they needed to be replaced. Took it to another dealer (my trusted dealer) and they said that the other guy had no idea what he was talking about... that they tie rods were in perfect shape, and an alignment wouldn't be a problem.
Idiots...
__________________
Jackson - My Site
Old 01-13-2005, 05:58 AM   #20 (permalink)
How would a problem with the steering translate into a vibration issue at highway speeds?
Matt
__________________
Old 01-13-2005, 06:01 AM   #21 (permalink)
loose steering or ball joints will allow a wheel to oscillate left to right as it travels down the road, resulting in vibration.
bamachem is offline
Old 01-13-2005, 07:33 AM   #22 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
might also check for a bent rim....
Sam's wholesale had done that now to 3 of my rims when breaking the beads off of the old tires. I'm going to get new rims on my own dime one more time (I get em for cheap.) If they screw 'em up the isht is hitting the fan from here on out!
They also have done that to 2 of our dually's BIG steel wheels...
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 01-13-2005, 07:46 AM   #23 (permalink)
did they use the adapter to balance them? on the stock al rims the center is not machined to match the wheel. Therefore you must use a adapter that centers the wheel using the lug holes...
__________________
98 Taco TRD, 98 Taco 2.7ltr
TacomaTRD is offline
Old 01-13-2005, 07:53 AM   #24 (permalink)
ugadawg95's Avatar
Send a message via MSN to ugadawg95 Send a message via Yahoo to ugadawg95
Do you have anyone there in AL that will swap tires/wheels with you to see if the problem goes away when swapped? I would be happy to do that if you are ever in the Athens, GA area. It sounds like a bent wheel to me.
__________________
Stephen
SOLD! 99 4Runner Limited, Jade Mica.
08 4Runner Urban Runner Edition 4wd. Blizzard Pearl White...Let the mods begin!
ugadawg95 is offline
Old 01-13-2005, 08:09 AM   #25 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
I agree totally....you need to find someone with no vibration that will swap wheels. This will eliminate the guesswork as far as it either being in the rim/tire or somewhere else. After chucking the Revos and finding the same problem with the michelins, I think it is time to take a different approach to solving your problem.
bamachem also had a good point to look for the steering components as a possible cause.....you can do this yourself with the help of an assistant. Just have the person sit in the truck and move the wheel side to side while you are underneath watching the steering rack and tie rods. You can also put your hand on the inner tie rod boots to feel if there is play in them. Last you need to look at the steering rack as a whole moving (there is often play in the bushings) where you may have excessive play in the rack itself. Ball joints usually make a clunk sound when bad but you can jack each wheel up and move the tire in and out and watch for any movement there as well.
First just find someone else with a set of wheels that fit yours and do a temporary swap.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
16x7 Limited Wheel Weight dragr1 95.5-2004 Tacomas & 96-2002 4Runners 4 09-24-2007 08:47 PM
Balance of weight for jumping bsebllhglyknit The Fab Shop 0 12-22-2006 03:00 PM
Anyone use Dyna Beads for wheel balance? Mason Dixon Tires & Wheels 3 06-16-2006 06:07 AM
2001 16x7 Wheel Weight mochoajr 95.5-2004 Tacomas & 96-2002 4Runners 2 11-06-2003 03:12 PM
Wheel weight Praufet 95.5-2004 Tacomas & 96-2002 4Runners 4 06-23-2003 04:57 PM
2009 InternetBrands, Inc.
