ADDCO front stabilizer bar (3rd gen) - what's the stiffened angle bar for?
Hi,
The ADDCO kit for the front stabilizer bar included 2 pcs of stiffened angle and 2-M12 bolts and nuts/washers. I don't know where to place these parts since the stock bars does not have them. Does anyone know where these things should be installed? I'll also be needing some pics on the installed angle bars.
Will it result in something bad if I don't install these parts?
There's no mention of these parts in Gadget's and J.A.'s sites.
BTW, I was happy after test drive after installing the front and rear stabilizer bars and using ES greasable bushings. There's a very big improvement in handling and body movement. Glad I waited for the bars... Next will be the installation of the Sonoran diff drop kit.
Thanks.
Thanks.
If its the welded triangle thing it supposed to bolt onto the factory sway bar mounting bracket. I snapped my factory sway bar endlinks after a couple days of usage. However now my addco endlinks are bent. I dont know why maybe the bar was improperly installed.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
crashburnoveride
07-10-2015 06:39 AM
