acura/honda seat swap? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-05-2009, 10:31 PM   #1 (permalink)
sdsurfer's Avatar
i just installed RSX seats in my 96 LTD 4X4 anyone care to see?
later
sdsurfer is offline
Old 06-06-2009, 06:06 AM   #2 (permalink)
really? i take it you had to make your own brackets? or modify the acura ones? I've always liked the rsx/ s2000 seats so if it's not to difficult i may start searching for those again. If you could post pictures that would be awesome.
jdmaccord6 is offline
Old 06-06-2009, 07:00 AM   #3 (permalink)
sdsurfer's Avatar
i will post pics up in a bit. It was not easy at all. i had to remove 16 seat tower/footings and then screw the toyota footings to the acura seats/rails.
So
1st. Measure all the rails. compare the size of rails on new acura seats to the 4runner seats so you know how to mout the footings.
2nd. remove all footing making sure to label them as you go. A drill, hacksaw, a bunch of drill bits will all be needed to remove acura footings. They are welded, spot welded and riveted. PIT ASS
3rd. re install toyota footings on acura seatrails and the seat belt too. I had to use 7 washers for spacing the seat belt out.
In the end all worth it!
200 dollars for seats and 7 bucks in hardware from Home DePot.
pics below show stock seat side by side and the beginning of footing removal.
With hard work, drilling, sawing and hammering these brackets WILL come off.
now for the final pics...
sdsurfer is offline
Old 06-06-2009, 02:07 PM   #4 (permalink)
KrashDH's Avatar
I like those seats they look good. Nice work. Looks like you can now comfortably take some hard corners. Height is the same since you modified the new seats with Toyota's existing rails?
__________________
'99 Tacoma 5spd 2.7 4WD Xtra cab TRD
K&N Intake, headers, Hella's, Magnaflow cat,
cat-back w/ Magnaflow exhaust, gray wire,
fosgate(s), Kenwood deck. Hopefully more to come.
'05 Banshee scream 5th element rear, setup for 7/7-->'06 custom welded steel DJ/trials frame.
Line-X frame coat. Avid BB7 mech. My first frame job. holding strong
KrashDH is offline
Old 06-06-2009, 03:26 PM   #5 (permalink)
sdsurfer's Avatar
I am n ot sure that acura rails and toyota rails are interchangeable. Removed and replaced the footings holding the rails up off the floor. Raises height about an inch. I am only 5'10 anyways. is this considered a 3rd gen mod?
sdsurfer is offline
Old 06-06-2009, 03:48 PM   #6 (permalink)
what did you pay for the rsx seats????
stepside trd is offline
Old 06-06-2009, 04:39 PM   #7 (permalink)
KrashDH's Avatar
Quote:
Ah I see now kept the footings and modified them to the acura rails...probably some fab work to keep the height stock after the install instead of an inch higher? I'm sure If I did this to my Taco my head would be brushing the top...
__________________
KrashDH is offline
Old 06-07-2009, 09:15 PM   #8 (permalink)
sdsurfer's Avatar
Quote:
rtft
haha
sdsurfer is offline
Old 06-08-2009, 12:40 AM   #9 (permalink)
scuba's Avatar
A VEEEDDDY NICE !!!
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 06-08-2009, 10:01 PM   #10 (permalink)
One_96TR4's Avatar
Send a message via MSN to One_96TR4
I always liked these seats. I did say I would have to swap them into some car I had. This may be a plausible aoption for me. I guess I'll be keeping an eye out for a cheap set of these sets!
__________________
'96 SR5 4x4 5speed, e-locked...Tundra/OME Lift.
Quote:
Originally Posted by Sleeper View Post
It's good to work on your own truck, it only strengthens the bond.
Praise the lifted!
One_96TR4 is offline
Old 06-09-2009, 06:58 AM   #11 (permalink)
jvh4513's Avatar
What year of RSX are those seats? Where did you find them??
__________________
96 4runner 4wd - OME suspension setup - 33x12.5 M/T's - 3" body lift - K&N cold air intake - Transmission cooler - Roof light bar -
jvh4513 is offline
Old 06-09-2009, 09:29 AM   #12 (permalink)
Buhundred's Avatar
Quote:
Looks like an 05 model or something like that.
__________________
96' 4Runner SR5
Bone Stock, 100K as of 7-9-09
Quote:
Aussie 4WD experts say if you want to head off into the outback, take a Toyota or a Landrover.
If you want to make it back alive, take the Toyota! ....or, If you see a mechanic under a Toyota, call an ambulance!
Buhundred is offline
Old 06-11-2009, 01:01 AM   #13 (permalink)
sdsurfer's Avatar
Quote:
it was out of a 2002 with 30k. here is ad. LOL he had wrecked in a DUI "none other hurt" and he had two empty 40 oz bottles in back seat. SOOOO funny. well sad too..
my truck is the ultimate CL truck. i will explain in sig later
peace myspace.com/sdsurfermarty
sdsurfer is offline
Old 09-20-2009, 08:53 AM   #14 (permalink)
tell us a bit about why you picked those seats please. Lumbar control is that dial on the side ? the leather(?) coloring almost perfectly matches your rear seats?
nothing power- like it is not heated is it? which keeps it simpler of course...
nicely done and way to stick with it
I would think the average person would never even notice those weren't stock front seats.
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Fact. Rr. Locker/Diff Breather Ext.
Old Man Emu lift springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders-prevent body damage!
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts/Bushwacker Extend a Fenders
all my photos are over on Facebook now-I gave up on photo hosting sorry....
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Tags
4runner, 95, acura, civic, footing, honda, interchange, remove, removing, seat, seater, seats, swap, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
seat swap? 89old blue 86-95 Trucks & 4Runners 18 03-19-2009 08:43 PM
seat swap? 69stepside 86-95 Trucks & 4Runners 8 12-16-2008 12:59 PM
Seat Swap Johannes 84-85 Trucks & 4Runners 7 11-29-2008 09:05 AM
wtb toyota 4x4 or honda/acura car 2500 ct 93rustedyota The Classifieds GraveYard 4 09-04-2008 07:28 PM
seat swap rottenagenda Pre 84 Trucks 11 07-22-2008 06:26 PM
2009 InternetBrands, Inc.
