Ack!!
Old 02-22-2003, 06:44 AM
Eighty7ToyTruck's Avatar
Ack!!
Ok guys, this qualifies under the young and stupid sector...
I was at a party last night... someone said "kick the turbo up", lol big mistake, went to yank a donut.... lost every belt on the engine let loose, so i got an alternator/cooling belt on it, but how the heck do i get my a/c and power steering belts on? i cant find a way to pivot any of the pulleys to get some slack... any help would be appreciated...
1987 4runner turbo 22re... single belt wonder!
Old 02-22-2003, 06:50 AM
Arnold's Avatar
There's a bolt on the idler pulley bracket that allows you to adjust the tension on the belt. I believe the A/C pulley has one as well.
Old 02-22-2003, 07:01 AM
Is it the 12mm one behind the pulley that is at a slight angle?
Old 02-22-2003, 07:03 AM
Arnold's Avatar
Yup.
Old 02-22-2003, 07:34 AM
ok, well i loosened it and the pulley didnt move at all... im gonna try again later.. i can live without p/s and a/c for now..
Old 02-22-2003, 07:36 AM
Arnold's Avatar
Try tapping on the pulley w/ a rubber mallet. Sometimes they stick.
Old 02-22-2003, 08:26 AM
Thanks for all your help. will try the big fine hammer thing later... lol update to come... working on the mower right now
Old 02-22-2003, 08:48 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Are you putting a turbo on the mower?
Sorry, could not resist
Old 02-22-2003, 09:01 AM
LOL, just mild shaving and straight pipes for now, btw i have 2 snappers with 319 cc motors.... one could end up with a turbo.. i know a guy who's putting a turbo on one of his mowers... but first
i gotta get the darned thang to move....
Old 02-22-2003, 11:09 AM
Shane's Avatar
loosen the nut in the middle of the pulley, then it'll move easily. Don't forget to tighten it back up afterwards.
Old 02-22-2003, 12:28 PM
jx94148's Avatar
I've always had to loosen the center pulley bolt and loosen the vertical diagonal bolt a bunch. (I guess its the tension adjustment) Then I tap on the vertical one to get the pulley to move.
Old 02-22-2003, 12:52 PM
Got it on.. went ahead and reused the old belt and saved the new one i already have for a roadside emergency... i loosened up
the top bolt only, about halfway out, got the belt over the idler, p/s pulley and about 1/4 the way on the crank pulley, and turned the motor over, woohoo it worked. thanks to all you guys who helped, ill worry about the a/c when it gets warmer...
bayoulee
11-17-2018 04:59 AM
davis10
3.4 Swaps
7
08-17-2011 09:34 PM
norflaballer
7
11-10-2007 09:12 AM
Quick Reply: Ack!!
