99 Tacoma Rear Suspension 6"
Alright so I have a '99 Tacoma with a 6" Fabtech lift which is the most rediculous rear suspension set-up. I'm looking for a leaf pack that will substitute for the AAL and 3" block. Any suggestions? The kit only has 15,000 miles on it, but the rear is already sagging.
The best setup would be getting custom springs from either Deaver or Alcan. These are a little bit of money, but, are real nice.
Im sure you also could check http://www.marlincrawler.com, Trailgear.com, All pro Offroad, etc, and see if their 6" leaf packs will do what you want them to do. I am not sure if the Tacoma leaf packs and the replacement packs for the older Toys are interchangeable with the spring hangers and shackles, there must be some adapters or they must work.
Also, getting a 3" shackle and a 3" spring would be an option as well.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
Vargntucson
07-04-2015 12:15 PM
