'99 4wd spring question
Old 01-22-2006, 04:44 PM
kev7706's Avatar
I just bought a '99 4wd with 130k and stock springs and shocks. As you can imagine, they feel a little worn. I plan to do light-moderate off-roading, but the truck will see a lot of pavement. I understand the coils on my particular model are an inch longer than other 3rd gens. So I plan to replace the shocks with Bilsteins and the springs with either OEM or Performance Products. My questions are: Are the PP springs the same length as the OEMs and how do the two compare in terms of strength (for towing) and off-road ability? I want to keep the truck at stock height or very close to it.
Thanks, Kevin
Old 01-22-2006, 05:46 PM
noahrexion's Avatar
The PP's will be a bit stiffer than the stockers. However you may only need some new struts to revitalize the feel of your truck. If you are set on the Bils; then maybe you should simply use those and leave the stock springs on there. The PP's will be very close to the height you are at now; yet if you plan to tow a lot with heavy tongue loads MAYBE the PP's will be better for you.
From what I have read a lot on these and other forums is that the PP/Bils combo is quite stiff and a lot of people end up changing. light-moderate offroading can easily be done in a bone stock runner. Maybe you should consider a bit lighter shock; like the Tokico Trekmaster (much cheaper as well).
Old 01-22-2006, 06:10 PM
kev7706's Avatar
Thanks, noahrexion. I'm looking into the Tokicos as I type.
Old 01-22-2006, 06:26 PM
X-AWDriver's Avatar
Tokicos are the same as the OEM and I got OEM for under $150 for the 4 shocks.
Old 01-22-2006, 06:31 PM
kev7706's Avatar
x-awdriver: do you mean that Tokico supplies the OEM parts for Toyota or do they just feel the same?
Old 01-22-2006, 06:34 PM
MTL_4runner's Avatar
Yes, Tokico makes the OEM 4runner shocks.
You could go with OME shocks if you want something softer.
Old 01-22-2006, 09:06 PM
noahrexion's Avatar
the trekmasters are totally different (stiffer)... yes tokico makes the OEM shock but the OEM shock is a lot softer. I love my trekmasters and they were $200 shipped
Old 01-23-2006, 09:56 AM
BADLNDS's Avatar
I have the PP springs and Bilstein shocks.
my runner sits about 1.5-1.75" higher than stock and does feel a bit stiffer. (but handles much better than stock) on the road its great...on the trail its bouncy but more than adequate for light off-roading. (it has plenty of clearance)
-B
Old 01-23-2006, 10:47 AM
4Runner4Christ's Avatar
Kevin, The shocks are no doubt toast, but I would question the need to swap out the springs. My guess is that doing just the shocks would meet your needs and save you some ca$h that can be used for other mods. Something to think about.
Old 01-23-2006, 01:25 PM
kev7706's Avatar
Thanks to all who responded. Glad I posted here before I bought. I'll probably keep the springs now and decide between Bils and Treks for shocks.
Old 01-23-2006, 02:54 PM
Are the springs in the rear sagging? is the rear bottoming out on bumps?
Old 01-23-2006, 05:09 PM
kev7706's Avatar
The rear isn't sagging. On bumps it makes a lot more noise than my parents' vehicles (Accord and G35), but it's supposed to ride like a truck and I doubt it's bottoming out.
coffey50
07-28-2015 10:55 AM
adammtb
07-27-2015 11:57 AM
ripp96
07-25-2015 02:32 PM
TokyoD23
07-12-2015 06:01 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: '99 4wd spring question
