98 T4R Collar nut just would not fit S13WE caliper?
Old 09-26-2011, 03:27 PM
mazaa's Avatar
Guys,
I have one OEM Rotor & S13WE Caliper installed on the truck, but just cannot get the collar nut to fit, does something needs to be trimmed?
I have read a few DIY and threads on it, but do not recall anyone else having this problem, a search did not turn up anything.
Should I just buy new brake lines for Tundra?
I will try to to post a pic of the brake line end as soon as my camera finishes charging?
http://www.flickr.com/photos/50011705@N07/6187195140/
http://www.flickr.com/photos/50011705@N07/5711719310/
Old 09-26-2011, 04:01 PM
habanero's Avatar
No trimming needed for the nut. Are the threads boogered in the caliper or on the nut? If you were to buy a new brake line you'd buy it for the (assuming you're working on a) 3rd gen 4Runner.
Old 09-26-2011, 04:05 PM
rworegon's Avatar
Collar nut? Do you mean the fitting/nut at the end of that hard brake line? Is so, once properly aligned it should thread in with no problem.
Well, unless habanero is onto something with boogered threads.
Old 09-26-2011, 04:39 PM
mazaa's Avatar
^Yep the nut at the end of the brake line. Ah!, I wish I had checked the threads on the caliper before installing them. Oh well I still have the old items at hand.
Possible to check with a 10mm bolt, if the threads on the caliper are ok, without having to take it off?
Old 09-26-2011, 10:47 PM
wyoming9's Avatar
Smile
Sometimes these can be a real pain to start.
Try with just a extra flare nut not on a line .
See if that threads in without any problems .
I have noticed with some rebuilt calipers threads get burred but most often clean up if your careful.
Old 09-27-2011, 05:10 AM
waskillywabbit's Avatar
Seriously. Sometimes you just gotta hold your mouth right. Those fittings assemble perpendicularly and if you are off just the slightest or boogered the threads they won't start. I bought a set of metric taps for each common size on Toyotas and now habitually clean out old threads when putting things back together. It makes an old bolt go in an old nut like butta.
:wabbit2:
Old 09-27-2011, 05:19 AM
Nelsonmd's Avatar
:wabbit2:
Good advice here. You can get a metric tap and die set from autozone for about $30. Not the greatest, but it has served me well so far, better than I expected. Gotten lots of use for cleaning threads.
Old 09-27-2011, 05:39 AM
habanero's Avatar
Seriously. Sometimes you just gotta hold your mouth right. Those fittings assemble perpendicularly and if you are off just the slightest or boogered the threads they won't start. I bought a set of metric taps for each common size on Toyotas and now habitually clean out old threads when putting things back together. It makes an old bolt go in an old nut like butta. :wabbit2:
For me it's eyebrow configuration. Metric tap set is a nice thing to have around, know it's saved me a few headaches. Good call as usual, Wabbit.
Old 09-27-2011, 05:50 AM
What is it with women and eyebrow configurations? My wife has those looks too. Even my boys have noticed it and asked me about it. I just told them when the eyebrows move, it's too late, you're already in trouble for something.
:wabbit2:
Old 09-27-2011, 06:19 AM
mazaa's Avatar
Great, i have a metric tap n die set already, i will take the wheel off after work n give it a go.
Old 09-27-2011, 04:31 PM
mazaa's Avatar
Many thanks guys, just got done with both sides. The first side still gave me a hard time but after about 20 mins of minor bending in various directions it worked. The entire drivers side took about 30 mins (including taking the old one off:=)....not complaining though.
Now just need to bleed n bed the brakes and I will have my new 199mm calipers, & rotors/pads. Cant wait to try out the new setup
Old 09-27-2011, 05:33 PM
narfy's Avatar
if you unbolted the line from the knuckle, u wouldn't have to bend anything around until you are finished plumbing the caliper...
Old 09-28-2011, 05:53 AM
mazaa's Avatar
Hm good advise but i did not think of it. I suspect that it had beem bent previosly, cuz the 2nd was a piece of cake n linedup perfectly
Whatever123
09-30-2015 12:12 AM
yoder519
08-17-2015 07:12 AM
klavender1
08-15-2015 01:51 PM
trailgoat
08-13-2015 05:54 PM
TDonkey
07-26-2015 10:14 AM
Quick Reply: 98 T4R Collar nut just would not fit S13WE caliper?
