98 runner stalling
Old 02-13-2004, 05:24 AM
MTL_4runner's Avatar
So does it appear to run better now?
Old 02-13-2004, 06:00 AM
CUBERA's Avatar
It runs better now with the air on. But with the air off i am thinking my idle is not right since it won't hold at a steady rpm, it just fluctuates from 600 to 700 rpm.
I did a search and found one guy with a tps or throttle position sensor that went bad at 27000miles.
I have 85,000- should i replace this gadget or do a full tune-up with wires and plugs?
What are the best plugs for the 3.4runners?
Old 02-13-2004, 10:40 AM
You an just check the TPS with a simple multimeter.
You should see 200-800 ohms with the throttle closed.
You should see greater than 3.3k (I believe) fully open.
Then vary the throttle by hand and ensure that the resistance varies smoothly throughout the range.
If it does then there is no sense in changing it.
I would replace the plugs with OEM ones from the dealer (dual electrode Densos).
Wires don't bother, the stock ones are very good.
See how that does and post back.
Old 02-13-2004, 04:14 PM
CUBERA's Avatar
Then vary the throttle b hand and ensure that the resistance varies smoothly throughout the range.
Thanx for the reply MTL. Do you happen to have a picture of what the TPS looks like and where it's located?
Great tips. I have a digital fluke i can check the sensor with.
I'll get the plugs tomorrow and pop em' in when i get a chance.
Should i get iridiums or just the dual denso's?
Once again thanx a bunch.
Old 02-14-2004, 09:34 AM
  #25
The TPS is in tha same pic from before:
It is the black part directly opposite the throttle cable on the left side of the pic.
Old 03-02-2004, 01:28 PM
  #26
3.4v6's Avatar
my 01 taco also has been stalling lately. i notice that it happens when im heavy on the gas and just let off all of a sudden. could this have something to do with the MAF or over oiling the K&n filter i have? thanks
jason
Old 03-03-2004, 07:16 PM
  #27
CUBERA's Avatar
So many factors with stalling. Who the heck knows really unless you got a dealer computer diagnosis gig.
I changed my fuel filter again (twice in one year), cleaned iac valve and throttle body, cleaned maf with computer parts cleaner, installed techron fuel system cleaner.
My amsoil filter is only 6months old and haven't re oiled it. I may try new oem dealer spark plugs next to make sure. Maybe a tps sensor and o2 sensors also.
It hasn't stalled since ive kept my fuel above 1/4 tank. I think i'll just make this a habit.
I wish i knew someone with a computer gig to diagnose. :cry:
For now i'll just be a parts replacer i guess.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 98 runner stalling
