98 4runner vibration fix!
If you have a vibration in your driveline you cant seem to fix it.... check your slip yoke on your rear driveshaft for play. Mine would have a bad viberation around 60-70mph and I found my slip yoke to have lots of play in the spline shaft. I had a driveshaft shop replace the slip yoke slpines for 300 bucks. Good luck
ashersullivan88yota
01-18-2022 05:37 PM
