YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-09-2013, 11:03 AM   #1 (permalink)
Personal Sales Rating: (0)
96 tacoma 3.4 not hiting on 1,3,5
wow guys im in deep truck had blown head gasket on cylinder 5.i shaved had the heads put new gaskets . timing marks lined up coils firing plugs to. cylinders are full of gas truck ran good even with blown head gasket.sounds like popcorn in the breather ?????????????
davidwells is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-10-2013, 04:35 AM   #2 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
if you hear a tapping sound like a marble is in the engine while it is running then that is generally knock. In your case it would be pre-ignition most likely.
Most likely cause is the wrong timing although it should effect the whole engine and not one side. If you are too rich that could do it too. Sounds like something was not put back together right, I would retrace your steps.
__________________
Just call me TA
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, Removed URD 7th & Added Coolingmist Meth injection kit, 2.0" Pulley, Doug Thorley Headers - My truck - My Youtube with lots more
All the Mods that can be done to 3rd Gens Thread
My thoughts on Gun control summed up nice:
Quote:
Originally Posted by sdstud212001 View Post
Guns kill people like spoons make people fat
Quote:
Originally Posted by Dare44 View Post
Im a firm believer in the saying "If you outlaw guns, only the outlaws will have them"
“Criminals love gun control; it makes their jobs safer.”
Texas_Ace is offline
Old 01-11-2013, 09:53 AM   #3 (permalink)
400yzturbo's Avatar
I had a similar situation. I rebuilt my engine and after 2.5 years of running perfect I tried to start it one morning and it wouldn't start. After 3 days of working on it i found that my timing tensioner just flat failed. I found I had no compression in 1,3,5 cylinders. The other 3 had decent compression. What had happened is whaen the tensioner failed it allowed just enough slack in the belt for the passenger cam to jump out of time. With a new tensioner it was back in running order. I had never heard of the tensioners ever failing on these 3.4 v6 engines so it was something I didn't even think about until I found the issue. I thought I would post this to maybe be of some help to someone in the future. Good thing is that these engines are Non-interference so you can just line up the cams again and put it back together, as long as your timing belt and other components are ok.
400yzturbo is offline
Old 01-11-2013, 10:17 AM   #4 (permalink)
Texas_Ace's Avatar
That makes sense^ That is where I would start, retrace your steps and make sure everything was put together properly.
__________________
Just call me TA
Old 01-20-2013, 02:35 PM   #5 (permalink)
Threadstarter [OP]
3.4 not hitting
Quote:
i hooked it to a snapon modis and it has large numbers for misfire on cylinder 1 at so many rpms says missin on 2 an 6 to and new coils an knock sensor wire on the way.
Old 02-13-2013, 12:10 PM   #6 (permalink)
Threadstarter [OP]
cam alignment 3.4 5vzfe
how to align the cams on rh - lh of a toyota 3.4 5vzfe
Yotatech
4WD Truck
Paid Advertisement
Tags
135, 34, 96, firing, gasket, head, misfire, order, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
