96 runner with sagging rear coils
Old Sep 17, 2006 | 01:34 PM
yotarunner96's Avatar
i have a 96 sr5 that was i had a lift on about a year ago, and recently took it off because of gas mileage. my rear stock coils are sagging really bad, infact almost sitting on the bumpstops inside the coils. should i try to find some 99 coils to fix this or would it be shocks also that would do the trick. and again i do want to stay stock.
Old Sep 17, 2006 | 01:41 PM
Elton's Avatar
you can go with the 99 springs or oder a set of 1'' taller springs and maybe some stiffer shocks if you tow alot
Old Sep 17, 2006 | 01:57 PM
if i were to go with 1'' taller springs in the rear would i have to worry about changing the front though?
Old Sep 17, 2006 | 01:59 PM
Elton's Avatar
you wouldint happen to have any pics ?
Old Sep 17, 2006 | 02:11 PM
not right now i dont, i think i would like to just find some 99 rear coils, i think that might work
Old Sep 17, 2006 | 02:39 PM
ebelen1's Avatar
If you get '99 springs, make sure you get new ones. Also, try to get the extra cone that came on the '99+ models. This should do the trick and it shouldn't be extremely noticeable that it is a little higher, especially if you normally carry stuff in the rear of your truck.
Old Sep 17, 2006 | 03:12 PM
Elton's Avatar
heres what i was talking about http://www.performanceproducts4truck...h+Lift+Springs
Old Sep 17, 2006 | 03:46 PM
Originally Posted by Elton
yea thanks, i have seen the pp springs. a buddy of mine has them on a limited. i dont know if i want those or stock springs
Old Sep 17, 2006 | 06:35 PM
rocket's Avatar
The PP springs will last longer. The 99 springs will have a softer ride.
Old Sep 18, 2006 | 04:10 AM
MTL_4runner's Avatar
If your choice is either PP or 99 springs then I'd go with the PP's. The 99s are very soft so even if you had an 1" over stock, if you load them up at all (too much gear, towing, etc) you'll still sag. With just 5 adults in the truck you'll probably ride dead level......add any baggage to that and you'll be sagging.
Old Sep 18, 2006 | 06:56 AM
why go with new 99 coils and not a set of used ones?
Old Sep 18, 2006 | 08:03 AM
ebelen1's Avatar
Because they'll be sagged by now if you get used ones. They're not very expensive from one of the on-line dealership guys here (Strap22, Evan at Northridge Toyota, etc.). They have a limited life.
Old Sep 18, 2006 | 08:42 AM
Skrillah's Avatar
I was getting ready to upgrade to the PP's myself, whats install like on these? I've upgraded the rear to bilsteins and given the corosive nature of the stock shock...it wasn't fun! I'm guessing i'll need a spring compressor but anything else I should look for....?
Old Sep 18, 2006 | 08:47 AM
Skrillah's Avatar
Didn't mean to steal your thread yotarunner96! Yeah, I would definitely agree with the others, if you're planning to keep your truck for a while don't mess around with the 99's...I mean they're not bad but everyone I've talked to said go with aftermarket.
Old Sep 18, 2006 | 06:20 PM
i suppose thats what i might do, i have already had aftermarket once. i took my lift off last spring to save on gas mileage. i had ome set up, but now back to stock which is great for highway driving and better gas mileage
Old Sep 18, 2006 | 07:42 PM
cackalak han's Avatar
Or you can go to your Toyota dealership, since the rear coils are on recall. I just had mine changed out. That will be your cheapest solution. But call ahead first to make sure your rig qualifies.
Old Sep 19, 2006 | 12:53 AM
what year is on recall
Old Sep 19, 2006 | 04:34 AM
Only 96-98's
.....but those springs are not as tall as the 99 coils so you'll begin sagging again almost immedaitely.
Old Sep 19, 2006 | 06:38 AM
Originally Posted by MTL_4runner
Only 96-98's
I've never noticed any sagging on my rear's--that's with the original springs and the new ones. Why would his begin sagging if he got new springs in there?
Old Sep 19, 2006 | 06:43 AM
Just from use......happened to me on both pairs (originals and recall springs), but I do alot of road trips with kids, baggage and sometimes towing. The stock springs just weren't meant for any real decent usage. They work fine for getting groceries. I'd like to see at least 1/2" of rake to the truck since the coils are so soft but even unloaded my truck sat near level.....which looks great if you aren't driving it.
