94m 4 Runner OBD II code reader needed
Old 12-02-2005, 06:45 AM
Dave Mooney's Avatar
Toyota fans:
Which code reader do I need for the 3.0 V6 94 model engine?
Who has one at the best rpice/quality match?
I know how to do it with the T1-E-1 jumper wire. Do i really need one?
Old 12-02-2005, 06:50 AM
TDiddy's Avatar
Hmmm... I thought OBDII was 96 and up?
Old 12-02-2005, 06:57 AM
celica's Avatar
just use the jumper wire and count the blinks as per the haynes manual. You don't need a code reader for this truck.
Old 01-09-2010, 09:39 AM
TFJ-4runner's Avatar
I thought this as well. In for verification on the matter.
Old 01-09-2010, 12:06 PM
MadCityRich's Avatar
correct. i did this for my old '95 pickup. works quite well. the system is much more primitive than OBD-II, but doesn't require a fancy computer to read codes.
MadCityRich
2002 4Runner
Old 01-09-2010, 01:31 PM
raydouble's Avatar
OBDII 96 +
A typical OBDII scanner will not work with an OBDI.
The only way to get the codes without a high dollar scan tool is to jumper the diagnostic box under the hood.
So, OP only needs to invest in a paperclip
BLRobertson
3.4 Swaps
07-10-2015 04:27 AM
94hiluxZE
06-22-2015 10:42 AM
DuckFan
11
06-18-2002 11:56 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: 94m 4 Runner OBD II code reader needed
