5VZ-FE head gaskets???
Old 03-13-2011, 08:49 AM
apmech's Avatar
I have a supercharged 98 4runner with a 190k. I am planning on changing the timing belt,water pump, valve cover gaskets, head gaskets and supercharger rebuild. Question is what head gaskets should I use Yota OEM or aftermarket??
Old 03-13-2011, 08:53 AM
mt_goat's Avatar
Is the HG blown now? If not, I wouldn't touch it. Its not really a common problem area with the 98 and up 5VZFE. I can understand the "as long as I'm in that far" thing but that's taking it too far IMHO.
Old 03-13-2011, 06:36 PM
apmech's Avatar
No the hg are not blown. I was going with "sense Im in that deep" plus the heads look easy to remove.
Old 03-13-2011, 06:59 PM
rworegon's Avatar
I agree with mt goat... It's a big job to do as 'preventative maintenance' and not worth the time if your HG is not blown.
Take a look here for a good idea of what is involved to replace the HG (hehe, mt goat posted the thread I thought I copied in here, so I will post my 2nd favorite):
http://www.ultimateyota.com/index.ph...6&topic=7462.0
Old 03-14-2011, 06:53 AM
mt_goat's Avatar
Originally Posted by rworegon
I agree with mt goat... It's a big job to to as 'preventative maintenance' and not worth the time if your HG is not blown.
Take a look here for a good idea of what is involved to replace the HG:
https://www.yotatech.com/forums/f2/5...askets-231472/
Your link is back to this thread LOL.
Here's a good thread about replacing the HGs: http://www.ultimateyota.com/index.ph...6&topic=2241.0
Old 03-14-2011, 09:34 AM
mt_goat's Avatar
I think checking the valve clearance would be a better use of time than replacing a good head gasket: http://www.ncttora.com/fsm/1996/SIL/...alcle/insp.pdf
Old 03-14-2011, 03:26 PM
rworegon's Avatar
Haha, that's what I get for cutting-n-pasting without double checking.
I swapped the link out to mastacox's thread since you snagged my 1st choice.
Old 03-15-2011, 03:12 AM
mt_goat's Avatar
Even better
Old 03-15-2011, 07:22 AM
Greg_Canada's Avatar
If its sealed nicely.... don't f- with it! you might have to machine the block surface then you gotta pull the motor, etc.
Also, you'll prob mess up some of the exhaust studs.
Honestly, leave it alone unless you want to pull the motor and do a full rebuild.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 5VZ-FE head gaskets???
