4WD question
4WD question
After having noticed this, it just made me curious so I figured I'd ask. When backing up or I guess even going forward slowly (like when you are at a stop and start to move) on a slippery surface like ice in 4-Hi, is it normal for the backwheels to slip some when you are trying to get up something, but the front wheels dont turn or slip at all until you step on the gas a bit more? Just wondered if it was possible for, hmm maybe some kind of vacuum leak or something (no idea) to cause the front driveshaft of an ADD system not to lock all the way or something, I don't figure there is anything wrong, but was just curious weather it was normal or not.
Thanks for reading,
-Bryan
Thanks for reading,
-Bryan
Originally posted by ravencr
I don't think anything is wrong. Mine does the same thing! This isn't an expert opinion by any means, though.
Chris
Chris
-Bryan
Usually when backing the right front will spin first for some reason. It could be spinning the RF and you don't notice since you can only see the LF.
Here is a pic of mt LR and RF spinning while backing before I had a rear locker. It looks like no power is going to the front axle but the Right Front is spinning just as much as the Left Rear. I got that stupid fat Ford out in short order, the driver was pissed that my old 4 cyl had to pull out his new 10 cyl.
And yeah, I haven't ever checked to see if the RF spun.
-Bryan
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
