4WD Light Blinking
Old Sep 13, 2006 | 08:19 PM
FTaco's Avatar
4WD Light Blinking
Hi Y'All,
I've got a problem with my 4WD that I'm hoping some of you may be able to help me with. The 4WD light (on the push button actuated system) blinks when I put it on, and the 4WD isn't engaging. Any help figuring this out is appreciated? Thanks in advance,
Doug
Old Sep 13, 2006 | 08:26 PM
YotaFun's Avatar
Are you just standing still or are you rolling?
And does it eventually engage or is it just constantlly stay flashing?
Old Sep 13, 2006 | 08:41 PM
FTaco's Avatar
It always blinks (when the button is engaged) and it blinks regardless of whether I'm moving or parked. The 4WD never engages.
Old Sep 13, 2006 | 09:08 PM
seanz0rz's Avatar
Guest
would help lots if you gave us specifics on your vehicle.
check front diff for loose vacume lines.
Old Sep 13, 2006 | 10:00 PM
FTaco's Avatar
I'll check the vacuum hoses tomorrow. I think based on the latest posts that I will be able to figure out the routing. As for the specifics, '95 Taco V6 SR5. It has about 260K km. I've never had any issues wrt to the 4WD yet. All of the posts related to vacuum hose leaks never pointed out a blinking light, so I thought maybe that was a tell tale sign of sorts (i.e. electrical maybe). Anyhow, there it is.
Old Sep 14, 2006 | 07:47 PM
FTaco's Avatar
bumpity
Old Sep 15, 2006 | 08:03 PM
Sparman's Avatar
I have a similar problem with my 02 4R with the push button engage on t-case lever. It is intermittent and very frustrating. Occasionally if I choose to engage 4hi - it'll blink and never actually engage. Then the entire system becomes unresponsive, and it may continue blinking for days. Out of the blue, it'll engage and work as intended. It's been extremely frustrating, I've posted about it here but it's a phantom and only affects 01-02 years - I believe. Some have pointed to actuator solenoids in the t-case, but as far as I know, nothing definitive has been blamed.
What I've come to find out about your year, however, is that it is most likely due to a faulty vacuum line. I'd start there.
Old Sep 15, 2006 | 09:43 PM
FTaco's Avatar
Thanks Sparman. I'll have more time to work on it tomorrow and I'll update when I know more.
Old Jan 15, 2007 | 01:28 PM
4runner02's Avatar
FTaco,
Have you gotten your 4wd system to work yet?
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
