4wd actuator does not operate when cold
Old 04-28-2015, 07:13 PM
anniesball's Avatar
I have a 2002 4Runner that will not stop flashing the center instrument cluster light when trying to engage 4wd when it is cold and snowy. The 4wd will will complete actuation when It is warm outside.
How do I test the operation of this system to determine what component is faulty?
Old 04-28-2015, 11:59 PM
wyoming9's Avatar
Red face
Define cold a little better ??
Like below 0 F or colder ??
Below Freezing ??
Then how often do you shift into 4x4 lots of time condensation can freeze causing these things
Things tend to stick from not being used
Vacuum switching valves like to stick from not being used.
The fact it works in warmer temperatures leads me to think it is freezing or just sticking from not being engaged.
Old 04-29-2015, 08:20 AM
anniesball's Avatar
4WD actuator
Not below freezing. Like 32-35 degrees F. I live in the Foothills of the Sierra Nevada Mtn range in California. I mainly use the 4wd for snow and the occasional offroad. I shift into 4WD at least a couple times a year.
Is there anything I can do to clean or lubricate to keep from happening?
Thanks
Old 04-29-2015, 01:38 PM
wyoming9's Avatar
Red face
When it is warm enough engage it several times .
You can look at lines if they are getting dry and brittle maybe time to change.
Does it work every time when it is warm out??
Old 04-30-2015, 07:42 AM
TheDurk's Avatar
Normally good advice, but...
He has an '02 4Runner. No vacuum to the ADD. It was all electric, TC and front diff, in '01 and '02.
There is a troubleshooting routine in the FSM for the electric ADD actuator, but the site won't let me post it since i already put it in here:
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
Remember, none of the stuff about VSV;s or vacuum actuators applies to you.
Old 05-01-2015, 12:18 AM
wyoming9's Avatar
Red face
I forgot the newer ones went all electric my brain is getting old and tired!!
Colder temperature more resistance on moving parts
shisha1999
09-21-2015 08:22 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
jetpilot
08-15-2015 06:48 AM
TokyoD23
07-12-2015 06:01 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: 4wd actuator does not operate when cold
