4Runner capacities and Amsoil product numbers.
Old 12-14-2006, 06:51 AM
rearviewmirror's Avatar
I thought some of you might find this information helpful. This is based on my 2000 4Runner 4WD w/ rear locker. (I'm in TX so I use 10W-30).
2000 TOYOTA 4-RUNNER 3.4L 6-cyl Engine Code 5VZ-FE
FILTERS
Oil Filter........ EAO57 AMSOIL Ea Oil Filter
Oil Filter........ SDF57 Super Duty Full-Flow Engine Oil Filter - ...
Air Filter........ 46109 WIX 46109 Air Filter
Fuel Filter........ 33319 WIX 33319 Gas Filter
Trans Filter........ 58805 WIX 58805 Auto Tran Filter 4x4
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 10W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Above 0°F......10W-30
All Temps......5W-30
Manual Transmission,.....GL-4
All TEMPS......75W-90
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Manual Transmission,.....GL-5
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Differential, Front W/ ADRD.....GL-5
75W-90
Severe Gear 75W-90
Differential, Front W/O ADRD.....GL-5
Below -18°C......80W-90, 80W
Severe Gear 75W-90
SAE 80W-90 Synthetic Gear Lube
Transfer Case,.....GL-4
75W-90
Transfer Case,.....GL-5
75W-90
Severe Gear 75W-90
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Clutch Fluid.....HB
CAPACITIES
Engine, with filter..........5.5 quarts[1]
Cooling System, W/O Rear Heater Initial Fill..........8.5 quarts
Cooling System, W/ Rear Heater Initial Fill..........9.5 quarts
Automatic Transmission, 4WD Initial Fill..........2.1 quarts[2]
Automatic Transmission, Total Fill
A340E..........7.6 quarts
A340F..........11.0 quarts
Manual Transmission, 2WD..........5.5 pints
Manual Transmission, 4WD..........4.6 pints
Differential, with ADRD Front..........2.5 pints
Differential, withO ADRD Front..........2.3 pints
Differential, with LDIFF Rear..........5.9 pints
Differential, withO LDIFF Rear..........5.3 pints
Transfer Case,Electronic..........2.5 pints
Transfer Case,STD..........2.1 pints
Old 01-26-2007, 06:46 PM
I forgot I posted this, I'm glad too, because I couldn't find the info!
Old 04-15-2007, 03:01 PM
octane103's Avatar
thanks for the info. just used it today!
msane99
07-17-2015 10:13 AM
bigjstang
07-12-2015 12:31 PM
Edionne13
07-09-2015 01:59 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 4Runner capacities and Amsoil product numbers.
