3vze Rough Idle and Exhaust Gurgle - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-16-2004, 06:48 PM   #1 (permalink)
First off, I am a new guy and I want to say that this site is great. I have been reading stuff on here for the last week and I still don't think I have scratched the surface. Now on the the question.
I have 1994 4x4 PU w/ a 3vze. It doesn't want to idle very well. The engine seems to idle a little fast and rough. I also hear and gurgling sound coming from the exhaust. The roughness is at it's worst just off idle. The whole trick shakes a little just off idle, other wise at idle it idle quality is just poor. I have removed the throttle body and cleaned it with carb cleaner. I did remove the TPS but I didn't see any carbon buildup or anything. I cleaned out all of the passages for the vacuum lines etc... I found a crack in the big hose the connects to the throttle body. I taped it up very well( the dealer wants $70 for a new one). I also removed the idle screw and cleaned it and the hole out. One thing that is odd is that the fuel pressure regulator is clicking pretty loudly. Is that normal?
One other question, why is there coolant going through the throttle body?
Thanks for any info,
Bill
whays is offline
Old 09-17-2004, 12:23 PM   #2 (permalink)
nunsa's Avatar
Bill
Greetings!
When you put your tps back on did you respec it with an ohmeter?
The coolant goes through the t-body because the computer bases the idle,injector opening, enrichment,...,off of different input sensors on the engine > tps,afm,temp. sensor...!
Do you have any stored codes on this engine? under ye olde hood next to the fuse box is a diagnostic connector, take a paper clip & jump "te" & "e1", turn your ign. key to on but do not start, count the "blinks" example: ** short pause *, would be a code 21, if there are more codes then there will be a long pause & it will flash the next code if you have only 1 code, there will be a long pause & the code will repeat itself, if you have no codes it will flash real fast!
Rough idle on a 3.0 could be an airpocket also in your cooling system, make sure you check that also!
Explain your "gurgling" out the exhaust, it doesn't smoke or any thing does it? You know that these 3.0 had an extensive headgasket recall!!
There isn't water/coolant coming out the exhaust is there!
Check your coolant!
Let us know!
__________________
The Master Toyota Tech,
2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package.
"Expert on the 3.0 Engine!"
Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply
US MARINE*** SEMPER FI
nunsa is offline
Old 09-17-2004, 03:06 PM   #3 (permalink)
Nunsa, thanks for the reply.
Did you know the Coast Guard and the Marine Corp have a common enemy?......The Navy!
Anyway,
1. I jumped the terminals and no codes just a quick flash of the MIL.
2. I had the head gaskets replaced under warranty about 100k ago. I also do not have any coolant loss issues or water in the oil. I have replaced the coolant every 30,000 with new orange prestone. Also no smoke or water coming out of exhaust. Well, this truck has always dripped a little water out of the tail pipe.
3. I marked the TPS with a scribe before I pulled it off. I installed it back in it's original position. I have not put a meter to it though.
4. It's funny that you should mention the air pocket deal. This idle stuff started happening right after I changed my timing belt. When I put new coolant in I ran the engine without the rad cap for a while and squeezed the top hose to try to pump as much coolant into the motor as poss. I poured as much coolant in as I thought I could and capped the radiator. After driving a couple of days I pulled the cap off to see if there was any more room for additional coolant and the rad was full. How would a air pocket affect my idle though? Also what is the best way to guarantee that the cooling system is full? Also, is the IAC controlled by the coolant going through the throttle body? Can the IAC be removed from the T-body with out opening up a can of worms?
5. The exhaust gurgle is hard to describe, i'll send you an email with a recording.
Any further response is appreciated!
whays is offline
Old 09-17-2004, 04:24 PM   #4 (permalink)
SolidDigital's Avatar
you needa adjust it with the meter, I can harly get mine right with the meter.. and even with a marking where it was origonally, it's probably still off. Just a hair movement can get it outa wack.
__________________
89 Deluxe Short Bed, 3.0 V6
5spd, 4x4, 31x10.5 BFG Radial Long Trails on 15x8 Pacer rims,
K&N air filter, high flow cat, Dynomax 2.5" Super Turbo muffler, Sunpro tach...
Fiamm 125db. low note horn
Pioneer 50w x 4 cd player, Polk speakers
SolidDigital is offline
Old 09-17-2004, 06:14 PM   #5 (permalink)
nunsa's Avatar
Anyway,
Like Solid Dig. said, you need to respec your TPS, try this link:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
As I learned from going to school for Toyota, the best way to get an air pocket out is to remove the upper rad. hose from the rad. and fill it with coolant here, reattach hose, turn heater to "hot" and watch her warm up and "burp" it works every time, if not, try a Toyota T-stat, they always worked for me!
A little water out the exh. is normal, no harm no foul!
If you have an air pocket, the temp sensor can't get a true reading of the engine temp nor the computer, thus the computer sees a cold engine and it will idle high..., because the comp. is enriching because it sees a cold engine verses a warm engine! What makes you think its the IAC! Don't you think it wold have acted bad before the t-belt?
Good Luck@!
__________________
nunsa is offline
Old 09-18-2004, 06:18 PM   #6 (permalink)
Nunsa,
To expand on the exhaust gurgle, the exhaust actually puffs a little more exhaust out the tail pipe?
Any thoughts?
whays is offline
Tags
3vz, 3vze, 4x4, exhaust, fuel, gurgle, gurgles, hot, idle, idles, pouring, regulator, rough, smoke, toyota, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Another 3VZE rough \ low idle in gear only josho 86-95 Trucks & 4Runners 8 03-23-2007 05:47 AM
90 3.0 rough idle, bouncing idle, rich condition Chuki 86-95 Trucks & 4Runners 1 11-04-2006 03:57 PM
exhaust leak causing rough idle? 91RN81 86-95 Trucks & 4Runners 2 03-02-2006 11:17 PM
3VZE- rough idle, stumbling, lost power...help! GregStevens Maintenance & Repair Archives 17 08-04-2005 02:57 AM
3.0 Rough Idle and misfire sound from exhaust EToy 95.5-2004 Tacomas & 96-2002 4Runners 13 03-30-2004 07:50 AM
2009 InternetBrands, Inc.
