3rd Gen Toytec or OME
Old 07-23-2010, 06:12 PM
02Runner.phxaz's Avatar
i drive a 02 4runner limited 2wd and am looking for a front coil option for a full 3 inch lift, need help deciding between
Toytec/Eibach front coil lift springs
Front OME Coils (95.5-04 Tacoma & 96-02 4Run) with a spacer to get the full 3 inch lift.
hopefully i didnt miss any threads about this while searching! if so i apologize!
Old 07-23-2010, 06:18 PM
Elton's Avatar
i guess 881s with top outs or 883s ?
Old 07-23-2010, 06:20 PM
waskillywabbit's Avatar
I've installed both and sell both. I think you would be happy with both.
If you are going to lift it, it will definitely ride better with all new coils/shocks.
The OMEs are nice, but the front coilovers in the Ulitmate Lift Kits are very nice.
http://www.wabfab.org/1996-2002-4Run...-products.html
Old 07-23-2010, 10:11 PM
yeah right now i'm using just 2.5 inch spacer lift, and running procomp es9000 shocks and struts, do you think either one would run better with these?
Old 07-24-2010, 06:00 AM
xskydivingdudex's Avatar
ya i think the OME coils will definitely be an improvement over the spacer lift. I have a 2002 2wd sport so take a look at my profile and u can see the lift im running bc i like it. Though u could get the 881s or 883s as elton said.
Old 07-24-2010, 06:11 AM
Both will ride much better.
Spacers load the springs unintendedly and make your ride harse.
Old 07-25-2010, 10:21 PM
probably going with the toytec eibach 3 inch lift front coils, will order from you wabfab next week
Old 07-26-2010, 05:21 AM
Let me know if you have any more questions.
Old 07-26-2010, 05:41 PM
yeah i have one more question, was thinking about adding my top spacers on top of my springs for a bigger lift, any suggestions or thoughts on that? looking for around a 4 or 4.5 inch lift.
Old 07-26-2010, 05:42 PM
You can't go more than 3" or your CVs will go boom.
Old 07-26-2010, 05:47 PM
ah ok thats what i figured, with rear ome 890 coils and eibtech front coils will i get a lot more lift than my 2.5 daystar spacers?
Old 07-26-2010, 05:53 PM
It will probably be close to the same amount of lift, but adjustable up front to where you want it, but it will ride MUCH better.
Old 07-26-2010, 05:54 PM
ok thanks for all the help, think ill just sell the spacers and go with eibach and ome 891 coils. and what do you mean adjustable up front?
Old 07-26-2010, 06:18 PM
The put together coilovers in the ultimate lift use adjustable shocks, so you can dial in your lift height.
Old 07-26-2010, 08:56 PM
arjan's Avatar
2WD doesn't have CVs last time I checked, unless it is a front wheel drive 4Runner of course.
Old 07-26-2010, 09:17 PM
yeah its not front wheel drive so it is probable?
Old 07-26-2010, 10:19 PM
arjan's Avatar
I was being sarcastic, 2wd 4Runner don't have the cv axles (front drive shafts).
Old 07-26-2010, 10:21 PM
Elton's Avatar
ive heard those eibach are stiffer than u no what
Old 07-27-2010, 04:33 AM
Whoops.
Nothing available to lift it that high except bracket lifts and those are probably 4WD only. 3" is max you'll find.
Old 07-27-2010, 05:56 AM
arjan's Avatar
Just keep stackin' spacers, why stop at 4"?
Quick Reply: 3rd Gen Toytec or OME
