3rd Gen 4wd rear driveshafts
Old 02-24-2008, 10:02 PM
iceman601's Avatar
Is there any difference in rear driveshafts, say from 96-98 and 99...all V6?
This is for a 97 2wd to 4wd conversion and I got a driveshaft from a 99 4runner and it seems like its about 4 inches short? I measured the distance from the front of the bellhousing to the rear differential drive flange currently on the vehicle and it comes out to be 88 inches.
I then connected the 99 driveshaft to my a340f transmission that came out a 98 Taco, measured the same way and its 84"....Am I missing something here?
Found this label on the driveshaft:
Would anyone happen to have some actual pictures to compare?
Old 02-24-2008, 10:56 PM
KZN185W's Avatar
The propeller shaft for those with multi-mode transfer case are shorter by a few inches because the multi-mode transfer case is longer than the regular transfer case.
VZN185L rear propeller shaft part numbers:
37110-3D250 ---> July 98 to Aug 2000 Limited
37110-3D300 ---> July 98 to Aug 2000 SR5
37110-3D310 ---> Nov 95 to Aug 2000 M/T
37110-3D350 ---> Aug 2000 to Aug 2002
Old 02-24-2008, 11:12 PM
iceman601's Avatar
Yup....just found that out.... a little too late. Fully compressed it measures at 45"
Now I'll have to sell these and get the correct one
Thanks
Old 02-25-2008, 07:35 AM
Taro's Avatar
Depending on cost considerations you can have a driveline shop retube it to make it the right length. And you can upgrade to thicker wall tubing while your at it. It's a 4wd now right? Can't hurt to add a little beef to that driveshaft.
I had mine done recently and it cost me $150 to go to 0.095 wall tubing and have it rebalanced, stock is around .065. My stocker was bent anyway, u-joints were fine and reused.
Old 02-25-2008, 07:43 AM
iceman601's Avatar
Its still in 2wd right now....was planning on doing the swap next week, but I guess it will have wait a little now.
I'd figure it will be easier just to sell this one and find the correct one as I don't know any reputable shops around me to do it.
Old 02-27-2008, 03:09 AM
KZN185W's Avatar
Originally Posted by Taro
.... u-joints were fine and reused.
the rear propeller shaft of the 4WD 4Runner uses double cardan joint at the transfercase so the old 2WD u-joints can't be used.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
TokyoD23
07-12-2015 06:01 AM
tpd143
07-07-2015 09:06 AM
Quick Reply: 3rd Gen 4wd rear driveshafts
